Pulled along side a very nice looking 300ZX the other night on Mona Vale Rd - at a set of lights.
I looked in, his G/F in the passenger seat just smiled. I raised my eyebrows....
He moved forward a little....
I moved forward a little.....
I gave my car a bit of a rev....
He knew it was on !
I looked down at his car - HKS sticker, Sard, APEXi and other stickers lined his front door
I knew he wanted to race.
I was ready.
Then he revved his car.
SHIT - I'm not racing that - It sounded MEAN !!
I chickened out !
He took off
I flashed my lights at him (nice car mate) as he took off in front of me -
I went home and sulked.
I need to do some more stuff to my car !!!!!
https://www.sau.com.au/forums/topic/5370-2blast-300zx/
My uncles stock 308 automatic VB commodore with broken exhaust manifold sounds mean, but dosent mean its fast :D
300ZX are much the same, put a decent exhaust on it and they sound fairly tough... and it never means that the driver is assured to put all the power down.. so go for it next time :)
https://www.sau.com.au/forums/topic/5370-2blast-300zx/#findComment-82249
can you spell p u s s y
Originally posted by giz01
hey a auto z with a good exhaust, pod filter & 14psi will run high 12's, i know a mate of mine has done it!
Huh ! ***** my arse ! Smart I say
Wait 3 weeks fellas , then I'll take anything on !! Then y'all will be saying Fark , remind me not to race that MuthaFarker of a Line !!
https://www.sau.com.au/forums/topic/5370-2blast-300zx/#findComment-82716
I haven't done this myself - But I hear ... short of taking the engine out, you have to dismantle the front suspension and get at it from underneath....
They really jam the motor into those things - I saw one the other day - You had to take one of the BOVs of to change a damn fuse in the fuse box !!
Nah - too labour intensive for me.... They are still horny as tho !!!
https://www.sau.com.au/forums/topic/5370-2blast-300zx/#findComment-82757
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
