Found anything yet?
The mrs is considering selling hers as you know...are you actually serious is the question? Your post is very vague and short.
Ie what about colour, kms, mods, price, location, condition, etc. I don't think its currently a "buyers" market, where people are going to chase buyers that only have $30k to spend.
I have had an extensive look around in the last couple of days and Oz wide there aint much for less than $35k - unless you want an auto, 4 door, or non-turbo - which all seem to be closer to $30k and some less!
Here are some nice examples: 34's for sale & more 34's for sale
Plenty for sale between $35k and $45k
Cheers :burnout:
https://www.sau.com.au/forums/topic/53939-wtb-r34-gtt/#findComment-1072740
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
