Upgarage.. where are you located? looks like sydney in the photos! i have seen a sprinta similar to that colour at my mechanics... but i think that was gonna use a 20v or std 4age with side draft webbers etc..
that was gonna use 6pot brakes and stuff too!
have you sprayed the outside of it yet? are you using for street or just drag/track?
  • Replies 154
bought foam from clark rubber today to sculpt a bodykit out of which I'll then make a fibreglass gelcoat negative out of.... custom bodykit begins after new years'.
  • 1 month later...
lol no red ... silver
and yeah these things are noisy enough.. so it has been sound proofed .. adding a rebuilt s15 tturbo .. new plenum in pics, diff just been rebuilt .. getting there slowly :D
Looks like I will be getting a daily driver AE86 and leaving the r33 gtst in the garage
AE86 comes with met brown faded and flaking paint, white bonnet, rust in the tail gate and a blown head gasket
Has 5 speed and Air cond :)
$300
Have not decided what engine to put in
My last car was a AW11 MR2 with black top 20v and motec M4 but cost got too high. I think I will put a 20V silver top and factory ECU.
so you want a N/A engine in it? There was a pink AE86 drifting at wakefield on the weekend, NA 4age .. was going good but something broke, needed more power fo the long, high speed corners.
what price can you get the 20V with gearbox and loom for?
I have not started looking for a engine yet
My blacktop 20V in a front cut and auto box with 13,000km cost me $1850 about 6-7 years ago. Was only about a 12 month old motor at the time. It took me 6 years to get the MR2 on the road (got married and bought a house :) )
Silver tops are anywhere from about $600-700 plus
I will probably use the box that is in the car and just get a complete 20v with ecu and afm for approx $1000
not progressed coz its a low priority...
we're spending some time recently trying to use the old engine that we took out of the car (4ac) gonna make a blow through carby turbo, with the carby housed in a pressure chamber to avoid fuel backflow. plus some thick head gaskets and piston shaving to reduce compression should see a nice engine ready for another AE86 shell :)
what about reinsforcement of the float so it doesn't implode ... prety sure i've heard this happen on blow through systems.
do you trust the gear set for the 4ac to cope with that power..
same thing for you Darrin.. i dont think the gearbox from the 4ac will handle the 20v 4AGE power and revs etc.. i havent looked into it, but wouldn't think so from looking at the one we took out of the sprinter here!
The gearbox should be OK
The 20v only has about 120kw at the engine and not alot of torque
13 years ago i had a TA22 celica with a worked over 3TG twincam a that had more power and torque than the 20V. They use the same gearbox.
That box lasted over 2 years of constant thrashing (I was 19 :) It did eventually break 2nd gear. Went of the wreakers and bought another $250 g/box
If I was to turbo the 20v then i would start to be worried about the box.
fair enough darrin, they just look pretty weak is all. shame we gave away and exedy clutch that was in the car we bought, no use for it.. the block had 2 holes in it. damn rod went for a trip around the block lol
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
