Upgarage.. where are you located? looks like sydney in the photos! i have seen a sprinta similar to that colour at my mechanics... but i think that was gonna use a 20v or std 4age with side draft webbers etc..
that was gonna use 6pot brakes and stuff too!
have you sprayed the outside of it yet? are you using for street or just drag/track?
  • Replies 154
bought foam from clark rubber today to sculpt a bodykit out of which I'll then make a fibreglass gelcoat negative out of.... custom bodykit begins after new years'.
  • 1 month later...
lol no red ... silver
and yeah these things are noisy enough.. so it has been sound proofed .. adding a rebuilt s15 tturbo .. new plenum in pics, diff just been rebuilt .. getting there slowly :D
Looks like I will be getting a daily driver AE86 and leaving the r33 gtst in the garage
AE86 comes with met brown faded and flaking paint, white bonnet, rust in the tail gate and a blown head gasket
Has 5 speed and Air cond :)
$300
Have not decided what engine to put in
My last car was a AW11 MR2 with black top 20v and motec M4 but cost got too high. I think I will put a 20V silver top and factory ECU.
so you want a N/A engine in it? There was a pink AE86 drifting at wakefield on the weekend, NA 4age .. was going good but something broke, needed more power fo the long, high speed corners.
what price can you get the 20V with gearbox and loom for?
I have not started looking for a engine yet
My blacktop 20V in a front cut and auto box with 13,000km cost me $1850 about 6-7 years ago. Was only about a 12 month old motor at the time. It took me 6 years to get the MR2 on the road (got married and bought a house :) )
Silver tops are anywhere from about $600-700 plus
I will probably use the box that is in the car and just get a complete 20v with ecu and afm for approx $1000
not progressed coz its a low priority...
we're spending some time recently trying to use the old engine that we took out of the car (4ac) gonna make a blow through carby turbo, with the carby housed in a pressure chamber to avoid fuel backflow. plus some thick head gaskets and piston shaving to reduce compression should see a nice engine ready for another AE86 shell :)
what about reinsforcement of the float so it doesn't implode ... prety sure i've heard this happen on blow through systems.
do you trust the gear set for the 4ac to cope with that power..
same thing for you Darrin.. i dont think the gearbox from the 4ac will handle the 20v 4AGE power and revs etc.. i havent looked into it, but wouldn't think so from looking at the one we took out of the sprinter here!
The gearbox should be OK
The 20v only has about 120kw at the engine and not alot of torque
13 years ago i had a TA22 celica with a worked over 3TG twincam a that had more power and torque than the 20V. They use the same gearbox.
That box lasted over 2 years of constant thrashing (I was 19 :) It did eventually break 2nd gear. Went of the wreakers and bought another $250 g/box
If I was to turbo the 20v then i would start to be worried about the box.
fair enough darrin, they just look pretty weak is all. shame we gave away and exedy clutch that was in the car we bought, no use for it.. the block had 2 holes in it. damn rod went for a trip around the block lol
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
