Hello to all Queenslanders :D from a fellow SAU member .
I'm coming over for a bit of R & R (as much as I can with the missus & 3 kids in tow)
from the 3/11 to the 11/11 on the Gold Coast.
I had a car organised through a friend of a freind who was working in a car yard (Until recently! Doh! )
So now I'm in the manure (tho I'm always in it , its only the depth that varies)
& any suggestions would be greatly appreciated.
Cheers ,
Troy Rep.
https://www.sau.com.au/forums/topic/54532-cheap-hire-carhelp-please-d/
You should be right if you just turn up at most places. My friends have had no trouble finding something. Stay clear of the bigger names (budet, delta, etc), as they are usually quite expensive. You may need a credit card for a security deposit, and you need a licence - but otherwise its pretty easy.
But for around $40 you can get something reasonable for a day.
I got pulled up recently for not having held my license for the past 5 years. I was 2 weeks short and was denied the car. turned out i was better off without it...
I assume your older though with three kids.. or you just think $1.00 for a raincoat is far to expensive :P
Cheers guys , thanks for your help ( & smart arse comments of course :P , not looking at anyone in particular.....CalaisT3RBO )
& yes I am a little older...this holiday is for our 10th wedding aniversary (...mmm must nearly be due long service leave....)
Some helpfull stuff , thanks
Cheers
Troy Rep.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
