Shauno, I love your enthusiasm, but I'll be racing the full season next year so thursday night won't be needed. But remember on the street a GTiR will desimate me, I need a good 200m run up :D
So the strip it shall be...
  • Replies 53
I honestly think it will be a while before I have a gtr worthy of a 12 but it shall be.......
it shall be.......
And squizz you know what they say:
It doesn't matter if you win by an inch or a mile-winnings winning
EAT MY DUST sucker!!!!!!!!!!!!!!!!!!
  • 1 month later...
I may not be able to go now :D I'm on call that week unless I can swap with some one, I may not even make it as a spectator. I definalty won't be racing as my cooler probably won't be arrived let alone fitted. Hey shauno I'll get Gracie to take the White atmo VL down and maybe you'll have a chance :( Maybe she can have a go against your civic .......ahem *cough* ... I mean prelude... :lol:
What i want to know is who is going to be running at the drags on the 25th of January. I me FWDDRIFTKING is bringing the hondie down, and hopefully big bro will have the atmo turbo siliva ready with new injectors and fuel pump. But is ricknismo going down to punish the GTR that is the main point cause that i have to see. I missed the Street Machines GTR effort cause i had to work.
Also down at the Drags last time when Ricknismo raced was a 1972 ford escort with a VR4 mitsi. motor in it. It managed to pull a 12.6 at 109mph on 16inch street rubber and a open wheeler diff pretty impressive stuff. The car was build by a Mech. engineer in Bundy who went throught uni with my old man. He has a 11 sec series III rx7. And if that aint fast enough for him he also has a 11.0 @ 122 MPH XC falcon with a 460 c.i big block with his own fuel injection system that he made from a wolf 3D. This guys is nut, he just has a pure need for speed
I am in for the 23 of feb(i think that is the right date??)
I hope that big VL monster is going to be there....
I need some number plates too.... I was still thinking 51IDA... which says slida.... don't know anymore crazy cool sugesstions....
Hey rick it's tops to see your skyline down there.... your not scared that is for sure.... I finally am in the process of getting my injectors and then it is bosch motorsports fuel pump and I am on my way.... all the way to the drags that is.... tops!!!
hey nismos car is running better mile an hour but slower times... those diff gears really really suck.... you just can't pedal it off the line... but I was pretty happy with the times.... it's what I expected.... it ran a best of 14.4 on High Boost - Nismo driving
and 14.6 standard boost with me driving....
it was fun anyway... and it didn't spit a turo this time... that was a good thing....
another question for all you tech heads to search up.... i'm not knocking anyone or anything.... however the big and little richo were up nismo about running no exhaust other than the dump pipe... they claimed that it burnt out valves.... has anyone ever heard of this?! it sounds sus to me but I haven't played turbo's for that long.... all I know is engines are heat pumps... air/fuel in then air/fuel out as fast as you can....
so in my opinion dumping the exhaust will only add performance not burn out valves..... makes the car easier to drive to cause with a nasty V8 beside you you just can't hear what your doing in a turbo car.... it really sucks when you *ahem* accellerate quickly to the speed limit beside a noisy V8 or worse still a mongrel rotory... you just can't judge what's going on properly....
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
