alright ... i know this is a austrilan skyline forum, but i wasn't able to find a U.S skyline forum. I am about to come in possession of a R33 GTS-T Series II, www.japimportsusa.com is doing the paper work on the car right now and registering it in the U.S. and since i am a friend of the owner, and because they need a back up for their mirage that's being converted to evo 5 and prepped for rally, he is willing to go for a straight across trade for my 04 WRX with helix up and down pipe, borla hush cat-back, perrin crank pulley, and Tein FLEX Coilovers. i'm wondering what you guys think? .. o and the cars will be imported to the U.S via legal actions, it's gonna be registered when i get it. I will be one of only 72 R33 owners in the U.S :P so i was just wondering first if you guys know of a U.S skyline forum like this one here that i can go to. and second if there's anything i need to look out for and check when i see the car next week. im a noob when it comes to skylines, buh i just couldn't pass up this deal. here's the link to the car im getting it should be the 5th car down on the page here: http://www.japimportsusa.com/Nissan.html alright guys thanks for the help :bananaman
https://www.sau.com.au/forums/topic/54991-r33-gt-st-series-ii/
How much is your WRX worth there?
How much is this R33 worth there?
Are you doing a LHD conversion or can you drive it as a RHD?
It would be good to own an R33 in the states since they are so rare, but also means finding someone to work on it, and trying to source parts may be a lot harder than your WRX.... that and its 8 years older than your WRX... Don't belive the miles on the car either, it is probbaly a lot more
What do you want the car for? racing? daily driving? dragging? etc...
well .. i've dumpped 3k usd into my rex... most expansive was the tein flex coilovers, i'd say with the millage i can get around 21-22k for it at most. and the skyline, is listed to sell at 38k, buh since i a good friend of his, .. and he want my car =X. he's gonna do a straight across trade. the guy owns a junkyard in japan, that's why he's able to get these cars, and also i want it for drift/autox/circit ... gonna go all out on this baby. and as far as parts go, i can get everything from the guy im getting the car from since he also imports cars. and if you guys dont mind about me being here.... or if you know of a U.S skyline forum, let me know :( thx
P.S It's still gonna be RHD, which's gonna be a hassle when i go to get some micky D or when i pay for bridge toll. i was thinkng of one of those toy hands and put tape on it :D just for fun
i'm still stuck on wether i should get it or not, buh i am going up to reno once again in two weeks to actually look at the car and decide. before that i have to get a reliable commute car. *sigh* this is turning out to a be a real hassle. i need to find the insurance for this thing too. O, and if you guys can give me any info on this car, since im really noob to it, it'd be great. displacement, turbo code, engine code, stock hp & torque, stock 1/4 mile time. any of these information would be great and thanks in advance guys.
Good call man, I honestly wouldn't even take a chance with that guy. No way would I put a '04 WRX on the line for a car that I most likely wouldn't even be able to get.
FYI I'm an American myself and plan on getting a WRX when I return stateside in a couple years, I'll miss my Skyline but the WRX is still a great car and if I were you I'd hold on to the one you have.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
