Today i couldnt be stuffed going all da way to BP so i went to Shell to fill the car up. When i went to turn the car on it coughed a bit but started so im like oook then... so after about 3 minutes of driving in a 80 Zone the car lost all power and turn off. Without panicking i rolled it with the speed i had into the far side lane and turned the hazard lights on. I tryed turning the car on, it coughed but turned on, and than turned off a few seconds later, i tried this several times but it still wasnt going to happen. Then this ass hole in a Ford Falcon comes right up my ass and gives his horn a beating and im like wtf, then he pulls up next to me and creates traffic on a 80 Zone and i go "What the fcuk is your problem c*nt, cant you see the fcuken hazard lights, isnt the other 2 lanes enought for you" with out saying anything he pulls up in front of me and did the saddest burnout i have ever seen in my life.
So than i rang a mate up and he came down, we had to empty the tank and fill it up with some of his fuel, the car then worked fine.
Anyone else ever had buggered up fuel from Shell?
https://www.sau.com.au/forums/topic/55027-what-an-f-asshole/
i hope u kept the fuel...
ive seen this happen plenty of times in other cars... generally water causes this.
You should be able to see it quite easily if u put it in a jar as they have different densities.
keep it and take it to the place and see what they say.... speak to the consumer affairs and also get a mechanic to do a full check of the engine etc.
u can take legal action against them.
theres been plenty of rain around here...
also if u have had the car checked out recently by a mechanic before you went there it would also work in ur favour.
this is true...
which petrol station is it so we know to stay clear
I dont know the address, its the intersection one on Stud Road with BP across the road, and car lovers across that.
Coudlnt it be Petrol poisoning by mixing Shell with BP?? That could have caused something.
The tank was near empty.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
