My turbo needs replacing(R33 GTST) and i,m thinking of a HKS gt2530. Apart from 3 inch exhaust my car is standard . WIll I be able to run this turbo and change things as I can afford to. or do I need to do the extras first?.. Am I better of overhauling my stock turbo with High flow wheels.. Any advice would be appreciated
https://www.sau.com.au/forums/topic/55091-hks-gt2530/
  • Replies 57
Stuff high-flowing, i've got a hi-flow and its starting to stuff up, i'm also due for a replacement. To high flow your turbo will be a good $1200+, you can pick up a second hand gt2530 for about $1500; spending the extra few hundred is worth it as you will get a quality turbo made by HKS, not a highflow that some guy in a workshop has put together. You can slap on just the turbo by itself, you will get more power by using the HKS dump pipe but the stock dump will also fit so you dont have to change this right away. Of course if you want to start running more boost from the new turbo you will need to start upgrading other support systems - fuel pump, ECU, injectors etc, but running the new turbo on say stock boost or a little bit more will be fine.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1075693
ive run a 12.5 with my 2530. I once said i thought this turbo was too small for a rb25 as it doesnt hold boost at the top end, but after some some observations of the boost guage it seems boost only drops off after 6500, so its not really an issue, just affects your peak power figure.
i dunno how itd go with stock ecu, as long as you check your AFR's on a dyno you should be fine.
Ill be selling mine early next year complete bolt on with all lines and pipes inc HKS stainless dump, for when the 2835pro goes on, but even now its a street weapon with great drivability.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1075939
I've never understood why there are so many people that keep saying that a 2530 is too small for an rb25, when for one, it is in fact larger, albeit marginally, than the standard rb25 turbo, and secondly, HKS recommendeds the 2530 as a rb25 upgrade. How do I know this? It is on the front cover of the 2530 installation manual.
As Sly has personally experienced, it is capable of producing a 12.5. Too small? I think not.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076164
Fane, i agree, if your future plans are to further increase your rb25's output beyond the capabilities of the 2530, then fitting one now would be a waste of time and money.
But i think it is worth realising that not everyone wants to be a horsepower hero. For someone who mainly wants a large increase in mindrange power and torque without sacrificing response, i cannot see why the 2530 would not be a very attractive option, especially when a good condition, second hand 2530 can be found for just under $2000.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076250
fane, what makes you believe the 2530 is too small? have you used one or driven an rb25 with one? The peak power it makes doesnt tell half the story. The midrange and response is awesome.
I have no problem with people expressing opinions, but without direct experience i think can be misleading to others. If i took you for a spin in mine im sure youd be grinning afterwards and might not think its so small :rofl:
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076302
also ive run side by side many times with cars producing up to 40rwkw more than mine, and either been dead even or beaten them, ie again, peak power isnt everything.
I do see your point, i went from 200rwkw stock turbo to 220rwkw, and thought it was a lot to spend for just 20rwkw! but the difference in power delivery and fun factor is chalk and cheese.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076309
An RB25 with a 2530 is the best street car i have ever driven. OK so i havent driven hundreds of setups but the thing was very impressive. It was so responsive and...well lets just say it was great turbo.
I think a 2535 would be much the same. As a road car thats fun and scares ppl i reckon they are on the money. Too small, to some maybe, but 230rwkws on tap irrespective of gear and a good spread of power makes for a fun ride.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076313
sly,
115mph... thats impressive!!
so you extracted more power from the 2530? what power does it make now @ what boost?
i just did 12.97 @ 104mph which i thought was a low mph.
the difference between a 2.1 60' and a 1.8 60' for me ended up being almost half a second at the end of the track so with some more practice and sticky tyres you could have a VERY low 12 in the bag.
congrats!
Evan
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076473
My 2cents......
Firstly, I would suggest a HKS GT over a rebuilt / high flowed for your car. No doubt !! ( Would be happy to elaborate if required )
On the topic of HKS GT's, while in Japan I was made quite aware that the perfect partners were, HKS GT2530 for an RB20 and then GT2535 for an RB25. This is of course for a reasonably sensible street car / track days. Personally, I think they were right but there are exceptions ( eg. using a GT2530 on an RB25 for drifting ).
My opinion..... GT2530 for great launches and awesome mid range with very respectable top end or GT2535 for a little less down low and a bit more up top.
Hope that helps ;)
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076583
sly,
congrats!
Evan
hi evan, no i havent got anymore power out of the 2530, Its actually making less than when i first had it tuned due to the addition of a cat in the exhaust, which im still running. I made 227rwkw without cat, and now make 218rwkw at just under 1bar, but run 1.2 bar till about 6-6500rpm (boost drops off after here).
yeah im pretty pleased with the mph! ive just been fighting axle tramp off the line which is why the 60ft time isnt so good. A 1.8 60ft time would definitly bag a very low 12.
Congrats on getting into the 12s!
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076635
I was reading a write up on a comparison on the GT2530(I think) and the GT-RS in zoom I think it was, was a very goof read. I'll scan it in and post it if anyone was keen to have a look?
The end result was that although the GT-RS lacked a little bit in top end the mid range response was awesome. It was picked over the GT2530 but price is a bit of a turn off.
https://www.sau.com.au/forums/topic/55091-hks-gt2530/#findComment-1076658
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
