i put motul 4100 turbo light in like 100kms ago so i cant really notice anything different yet and probably wont but as long as it keeps the car healthy i will be happy
Turbolight is nothing like the 300v series, turbolight is basically mineral oil compared to 300v
I beleive 300v better suits high output turbo engines primarily because thats what it was designed for, while mobil 1 and castrol R etc are good, they're still designed for mass use in any vehicle
300v series was designed and developed especially for racing conditions
Read the back of a 300v oil can after you just spent $40 for 2L and youll understand :D
i never said it was like the 300v stuff i know its not i was just stating thats what i use and unless he has a 250 + rwkw and takes it to the track he wont need the 300v. you cna always put better stuff in but unless its for a specific application eg track work its a bit of overkill
Because Motul say its made for racing, its better...LOL... Every person, every workshop claims the oil they use is better.
Best rule is to use good oil and filter and change regularly. Outside of that i dont think there is that much difference. One are i know where the Mobil is better then other oils is in its temperature stability. Throw on an oil temp gauge then go for a hoon and watch oil temps. Mobil 1 is a lot more stable then Castrol R and Repsol oils. A firned trialled a whoel bunch of oils, only really commenting on oil temps at the track, and the Mobil was the best.
OUtside of that, i dont KNOW, other then Mobil 1 served me well . Right now as i cant find the grade of Mobil 1 i like im usign Castrol R and hoping that my oil cooler is up to the job
Oils ant Oils. Well according to a Shell Lab Rat friend of mine, She said really the difference between the mineral and Synthetic oils is hardly any. Now thats in LAB and in controlled conditions.
As said change every 5000Ks and a good filter will do the trick to keep the Turbo Beast running for many Ks.
:thankyou:
Thats not what i meant, but still yes to that statement :D
300V is the only ester synthetic i know of, it makes 300v in a class of its own
and they now have double ester technology, i read the brochure for it and ive never seen so many explained benefits from just using 300v
each to his own i guess
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
