hey, the best thing to do if ur thinking of increasing power is to forget about an rb30. the main thing u want is the block. then u either want an rb25 head or rb26 head. this is because they are both double overhead cams, where the rb30 is single. if u place either the rb25 or rb26 head on the rb30 block u get a 40% power increase and if u have a decent exhaust and air intake its a bit more. i dnt know how much is ivolved for the rb26 head because it expensive. but the conversion to an rb25 head is very simple. its an amount of tapping it very carefully into place. and that 40% increase applies to N/A cars. so imagine the power if it was turbo.
hey, the best thing to do if ur thinking of increasing power is to forget about an rb30. the main thing u want is the block from a VL. then u either want an rb25 head or rb26 head. this is because they are both double overhead cams, where the rb30 is single. if u place either the rb25 or rb26 head on the rb30 block u get a 40% power increase and if u have a decent exhaust and air intake its a bit more. i dnt know how much is ivolved for the rb26 head because it expensive. but the conversion to an rb25 head is very simple. its an amount of tapping it very carefully into place. and that 40% increase applies to N/A cars. so imagine the power if it was turbo.
But that being said.. If you are going to the expense of a motor build you would probably be better off building it to suit turbo or even better buying a turbo model & rip the turbo off if insurance is too high then drive it around as NA for a while until you can justify spending the $$.
I am not doing this conversion - but am quite interested in what you are saying here...
Basically what i gather is tha; build a high compression RB30DET, take off the turbo?
and drive it as an RB30DE - then its just a simple matter of bolting the turbo back on??
EDIT: I've thought about this with a mate - and just seems unpractical.
tuning, exhaust, intakes and lil bits an pieces need to be changed...
dis-regard the post // but will leave it for others.
  • 1 month later...
*poke*
i'd like to restart any discussion on the rb30de... more specifically with the 26 head.
if anyone has done the 25/30 or 26/30 conversion care to post any dyno graphs or 1/4 mile times?
what compression do you run 10:1? 11:1? did you retain the vvt? (how do u tune with the vvt?) etc...
yes i've read ALL the pages in the forced induction section, but it doesnt cover the questions related for n/a applications.
thanks
Eug
  • 4 months later...
10.5 with the rb25de pistons, sounds good to me.
Would forged pistons/rods be necessary when running comp that high? or should the rb30 rods and rb25de pistons be enough.
My rb30 has done 230000kms, would a basic rebuild (bearings, hone the bores and new rings on the rb25e pistons) be advised or would I get away without doing it. Or does it depend on what it all looks like inside?
Would a brake upgrade be required for the power increase? (i have a r31 silo)
10.5 sounds good, i'd be inclined to go to 11 if possible.
i've read that a few of the 30DET guys using stock parts so i cant see why not.
forged pistons wont be necessary, however lightweight pistons wud be good.
yes it does depend on the condition of the block.
brake upgrade would be advisable but a good set of pads and rotors may be sufficient depending on how u drive.
eug
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
