After installation of the deck there was no lights inside the car, no room lights or those reading lights?? any possible wire i could of connected wrong or cut which wasnt ment to be cut? colors or any details would be a great help peeps!
Unfortunatly i didnt no about this site when installing so couldnt follow the guide :D
Very common problem for home stereo installs. People get the dimmer wire mixed up with the Earth..... When the parkers are off its an earth, when they get switched on - its alive, and will throw the fuse.
There are 3 fuse panels in the R33, when I blew mine Im sure I replaced one in the boot.
Cheers
Sumo
Sumo, if this was the case when i put the parkers on wouldnt the deck turn off and throw the fuse? ive checked boot fuses, checked the fuses in the cabin, none blown? do i need to re wire it? any ideas as to what colour wire i have done wrong?
did you use a multimeter to identify the wires?
If not, now would be a good time.
First things first you have to find the bad fuse, one must be gone somewhere, sometimes it is hard to see, swap them with your spares on by one with the deck off.
Thats another good point SKYL9, that rheostat might have a wire off it.
BlackR33, Yes, first time it goes to blow a fuse, it will turn off for a couple of seconds - once blown it will not go out.
Use a test light for fuses, And yes, I did the same thing when I first did my stereo. I had no interior light/dash light/cigarette light
Cheers
Sumo
nah . you have killed 3 fuses. there is one in the back for tail lights the interior light one is in the panel above your right foot.
if you go out and buy an adapting plug for $20 it will save you the headache of the above and also another $80 or so that strathfield or the like will charge you to fix it. ( I charge $85 to fit one..)
this is really doin my head in, because ive checked every fuse in the car, when i got this problem i got a test light and tested every single fuse, first thing i did.
depends on who complied it. most of the ones I work on have a seriously botched item literally thrown in. if its the factory item then you have killed a fuse. those things arent that easy to kill..
Mate, have your stereo pulled out and go see an auto elec, they should not need more the 10 minutes to tell you whats wrong..... Just explain the symtoms, and they should be able to sort things out. It is a common problem with people that install their own stereos. I have seen a few blown up stereos from incorrect installation - just because people think they can save a few dollars by doing it themselves.
Cheers
Sumo
I've installed countless stereos - and I don't consider myself any sort of installer but I've never blown anything up.
How does this sort of stuff happen? Is it something I'm not thinking of or isit the most obvious stuff like shorting wires while they're being cut and stuff like that?
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
