Does this look the part?
http://board.performanceforums.com/forums/...30&pagenumber=1
Fairly cheap and the build quality looks good. Not sure about the box shape design though, shouldn't these things taper back so that air speed increases towards the last couple of cylinders (furthest from throttle body)?
Not sure about everyday driveability with it either. So, who wants to be the guinnea pig and get one first? :)
Oh, haven't got one yet. You'll know when I do, I'll be the git running around with an ear-to-ear grin :lol: Besides, can't get one without a bit of fuel control, the stock ecu would get pretty confused with something like that bolted on. Hell, the stock ecu is pretty confused even on a stock car.
Cutting the end off the stock plenum is one way to go, but I don't think its going to be healthy for anyone. Factory plenum is designed from the ground up to distribute airflow evenly between the cylinders with air entering from the center. Its not going to do its job too well (if at all) when the entry point is changed like that. But I think you were jking, so no problems :wink:
R34
Thats right and wrong.....That plenum would be OK if you were to run more than 20psi but under that you would definately cause some of the sylinders to run lean and some to run rich. It should also be tig welded on the inside as well or it will just blow apart at the welds after a while at around 15psi.....A plenum with square sides is not the best for air flow, just take a look at about every other plenum on the market for a better idea.......At the end of the day if you buy this you will have a $650 plenum that is worth $650 and will deliver $650's worth of benefit. The standard plenums on rb 20 and 25 are actually quite good for performance and flow well to all cylinders. I tested this when I had mine off and the cylinders all flowed the same volume at the same speed.
There is a lot of r&d that is needed when designing a plenum thats why they cost so much.
Cam
JiIMb0, the plenum basically acts as a resouvour for air til the engine calls for it. The engine sucks a lot of air and if you just had a small pipe the engine would stall as it couldn't suck in the volume of air that it needs.
[/quote:8c2559842b]
This plenum [b:8c2559842b]is[/b:8c2559842b] tig welded, also uses tuned length ram tubes and, importantly, accepts all std air bypass valves. While I agree that square sides are not best for air flow, I don't belive we'll see any cylinders run lean under pressure.
I'm sure most of us here would give our left nut for a Greddy or Jun plenum, but since we aren't all chasing after that 1/10th of a hp and we all have street cars that need idle control, this plenum doesn't look like a bad choice. I'm certain its better than the stock plenum, I have no faith at all in Nissans design choices in this area. Everything about the RB25det was designed to meet a price point, theres nothing on the engine (except the turbo) that makes it easy for us to get power out of it.
So yeah, its only $650 worth of engineering and manufacture but its still heads and shouders above the stock plenum. If anyone is up to the task, buy one and put it on a flowbench. I'd love to see the results :)
You really have to know how air flows before you realise that some designs work and some don't. I am not saying I know everything I was only saying that from what [b:04433b2acc]I have actually tested [/b:04433b2acc] the rb plenum works much better than most people realise. I too am looking for a new plenum and will either build my own using short runners or use a rb25 GReddy item and modify it to fit. Regardless of cost if you are going to the expense of doing a mod it had better be worth while. Unless you run more than 20psi there is no need (other than better intercooler piping route) to change the plenum. Remember that for $700 there are many better mods to perform.
I am a HUGE fan of bang for your buck....cam gears @ $350 for 10-15% increase in power is what I am talking about as an example.
If anyone does buy one of these please get it flow tested prior to fitment at the SAME boost level you are intending to push through it.
Perhaps Gradenko will buy one first and prove me wrong.....I will be happy to know that a simple cost effective design actually works.
Cam
Thanks meggala, had a bit of a hunt around SDU and found a pic of dans plenum. Still has right angle corners but its a fair bit curvier than one for sale. Wonder what the insides are like? Maybe dan dooorift could let us know...
Looks good tho, and has factory idle control bolted up too.
Heres a link, http://www.geocities.com/medved_skyline/car/ click on Dcp_0005.jpg.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
