I've tried to measure the offset of my stock R32 rims. It's a bit hard to be sure on the car but they seem to have 40mm offset.
If my 6.5" R32 rims are 40mm offset and Gtt rims are 7" would 35mm be near the ideal offset?
Does anyone know what the actual Gtt offset is?
They are 7.5 wide not 7.
Stock tyre size is 225/45/17.
Offset is roughly 35 front, 38 rear. - May want to double check that
Are you sure the offset is different front to back?
I bought a set of GTT rims today and they are all the same. The offset seems to be 39 or 40mm. It's a bit hard to measure to the mm with the tyres on.
From outside to outside the rims are 22mm wider than my 6.5" R32 rims so yeah, they are probably 7.5".
Anyway they look like a 100% legal upgrade for the R32 :)
Yes i was wrong about the offset. That was the offsets for 18x8 and 18x9 to fit my car. Nfi why i remembered at the time that they were stock offsets.
But yes they are most definitely 7.5 wide. Tyre placards etc state it.
I tried fitting them today.
Julzz was right, the fronts don't quite clear the TypeM caliper.
A 3mm spacer would fix it but aren't these illegal?
They only just touch as you fully tighten the wheel nuts.
Actually there would be plenty of thickness in the caliper to shave about 2mm off the edge that touches the wheel.
Is this too bodge?
  • 3 years later...
Is this too bodge?
majority of people shave off the Nissan wording on the caliper, this usually gives enough clearance for the rims.
id prefer to do that instead of spacers, as spacers are illegal.
Mine didnt touch the nissan logo, it was far from it. It was hitting the whole edge of the caliper when the tyre was rotated.
I have 34gtt rims on my 32gtst, they are 7.5" wide. I'm running 225s on the front and 245s on the back.
Initially had to run a 3mm spacer on the front as the rims bound up on the brakes, when I changed to 33gtst brakes this problem went away and I didn't need the 3mm spacer (there is barely 1mm of clearance though).
  • 1 month later...
I have fitted r34 gtt rims onto a r33 gtst with no problems at all.. No need for spacers etc
However it might be ideal putting 3mm spacers on.
offsets are 38 (so i have read on these forums in the past threads)
I dont see why it wont fit a r32.
They got smaller brakes right? compared to 33s? if so then will fit perfect
I have seen pics of 32s with 34 gtt rims :P
bubba- WOW you got 245s on a 7.5inch width rim?? how? lol
thought 235s would be the most..
Edited by siddr20
Yup same here.
however, its like a mm off from touching.
Rims still rotate freely!!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
