  • Replies 47
yeah i'll get round to making one soon...
its just a cheapie... simota i think... something like that.. does the job tho :) and it was easy to install... took like 10mins for a n00b like me
lol thats cool doxxeh :)
oh yeah guess what i found out today... after owning the car now for like 3 months....
I GOT ADJUSTABLE SHOCKIES!! :D:D
i think thats what he said... shocks or suspension... cant remember... dont even know EXACTLY but have a fair idea, what they do... has 3 letters on it....
**EDIT H L and M
i think... High Low and Medium??
Originally posted by Ait
MMMm...nice one Nik! Damn I'm so envious of that front bar :)
Mine deeps into the hole behind the left headlight.
lol u and that front bar
yeah they had bends and stuff there to make it do that... but there is a plastic pipe (Air Duct) that leads from the light to where the POD sits....
my guess is that this used to have an aftermarket POD before they sold it as one of the bolts from the original box is missing and another isnt the original bolt...
still cant work out... thru lack of nderstanding if its adjustable shocks or suspension... im guessing shocks??
Pics a bit shoddy using lux
theyre adjustable shocks tho yeah?? not suspension...
the guy at Auto-1 who pointed them out to me had a look and said they look like KYB? i thikn i cant remember
Guest sleighty
hi there nice sound you have there,sounds like Doc's car now hehe...all you need is a bov and you will be set to go period!
To ylwgtr: sorry i didnt reply to you abt the supra intercooler as i am having exams right now but i will be going overseas in two weeks time so i guess i wun be able to see it anytime soon.good luck with your sale and hope to see u next year for more goodies that you have.
Originally posted by inark
im going to measure it up next week and get some aluminum and fibreglass made up to fit....
i need a sheild too, i will bring around my car and you can make me one too :(
re suspension... i beleive its made up of two bits , the dampers/shocks & springs. So basically you would say u have height adjustable or damper adjustable shocks/suspension. I think it would be damper adjustable rather than height, but i dont know too much about it, so dont take my word :(
lol dave... its got me even more confused now... i went to change them the other day cause i thought it had 3 settings... H for hard i guess, M for medium? and L for... er... low?
but it cant be cause look at it... if u change it so it points to the H it also points to the L on the other side of the dial... WTF?
or do u go on the dot? and if so why is there 2 Ms?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
