Has anyone had a noticable increase in fuel economy after tuning an aftermarket computer? A PowerFC is on my list of things to get down the track, but given the rising price of fuel if there was a decent increase in fuel economy it could be worth getting one sooner rather than later...
YES many users!!
Edited by siddr20
ohhh did you just ?
fark 4 years ago.. i feel old
This weekend i drove from paramatta to newcastle for $15. which is very good fuel economy. 150+ km (was $1.19c a litre BP ultimate)
PFC is the way to go.
i definately noticed better fuel economy since going from standard ecu + 200rwkw to haltech e11v2 and 280rwkw. how much better i don't know exactly, my fuel gauge has aids and is really inaccurate (eg. needle reads full for the first 100k's then drops quickly)
I'm hoping to get some "i get x more kms per tank" stories to work out if it's worth the cost.
~100km more and Night & Day difference in response.
Its a no brainer really, a properly tuned car is a beautiful thing.
i got 122km's extra to a tank after installing my power fc.
Time to start saving for a PowerFC then I think...
I got a *large* difference in economy after getting a power FC, it all depends on the quality of the the tune/your AFR ratio down the bottom end if you want to drive economically AND your right foot :ermm:.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
