Well as many of you may know I have been having some power problems for some time now, took the car to a mechanic on friday as last thursday my car decided to sound like a WRX, found out my pistons are screwed so looks like i am up for a engine rebuild, not very happy but a result from running 12 psi with only a stock intercooler in our hot climate. I always thought this was a safe pressure to run. i guess i will stick to 10psi until i can get myself a FMIC.
Im awaiting the bill from the mechanic hope its all fixed and ready for the MSCIII.
https://www.sau.com.au/forums/topic/55417-need-new-pistons/
hmm after finding out getting new pistons done is going to cost me over 4g, i am just going to replace the engine.
4G!! who quoted that? U can get good new forged pistons for about $1300
So if all u wanted to do was pistons then it shouldnt be more than 2K max.
If Changing engine you must, then transplant godzilla engine you shall :D
https://www.sau.com.au/forums/topic/55417-need-new-pistons/#findComment-1083084
um nah just getting another s2 engine found one for 2g so going to grab that, 4g for the pistons was only after everything like labour and rings and everything like that. yeah the pistons themselves were only 1300. either way i figure i am going to gwet screwed over so im pretty cut.
https://www.sau.com.au/forums/topic/55417-need-new-pistons/#findComment-1083602
wouldn't worry too much ben.. if you can get that engine for $2k and its all ok, you should get at least $1000 for you old engine if you separate it into parts - probably a fair bit more. People are always chasing bits and pieces that most wreckers tell them they have to buy the whole thing.
head: $600
coilpacks: $200
ignitor: $80
loom/ecu: $400 (if you don't need these)
bottom end: $300 (even if it is dead.. people might want spare stock pistons, etc)
etc, etc..
For instance, I need a stock manual flywheel ;)
https://www.sau.com.au/forums/topic/55417-need-new-pistons/#findComment-1083895
I could have done the whole job for you for $2500.
I just did mine myself...all up cost me $3200 but I put another head on it and moly rings and race bearings. did button clutch and cleaned all the injectors too.
Anyway....hope your other engine works out and let me know if you want a hand dropping it in. I'm in Brissy also.
https://www.sau.com.au/forums/topic/55417-need-new-pistons/#findComment-1084020
that 2500 is that stock pistons or upgrade? coz i might take you up on that offer.
https://www.sau.com.au/forums/topic/55417-need-new-pistons/#findComment-1084415
    • @GTSBoy are your spam bot senses tingling too?
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
