Would this be able to pump 2x12" Kenwood subs decently?
Can i use this monoblock amp & wire subs up in parallel??
FEATURES:
200 Watts RMS @ 4ohms
310 Watts RMS @ 2 ohms
400 Watts Max @ 4 ohms
800 Watts Max @ 2 ohms
Stereo in and out (to continue to a second amp)
High-efficiency MOSFET power supply FR4 PCB
Heavy duty heat sink
Die casting terminal and gold plated RCA jacks
Lowpass electronic crossovers with adjustable frequency
Variable phase shift control
Subsonic filter and phase shift
Adjustable input gain control
Short circuit/thermal/overload/DC offset protection
Soft delayed remote turn-on/off circuitry
Power/Protect LED indicators
4 ohm ratings are for a single speaker, 2 ohm ratings are for two speakers in parallel
https://www.sau.com.au/forums/topic/55423-800w-mono-block-amp-question/
the subs are:
KFC-W3009
300mm Component Subwoofer
[Feature Highlights]
Peak Input Power: 800W
300mm "Typhoon" Shaped Injection P.P.Cone Woofer (Black Colour)
Dual Magnet Drive
High Roll Surround
Aluminium Centre Cap (Red Colour)
Aluminium Model Name Plate for Back Side Installation
Sealed/ Ported/ Free Air Type Installation Capabillity
[General Features]
Impedance: 4 Ohms
Sensitivity: 93dB/W/m
Frequency Response: 25-800Hz
Size (WHD): 328x328x155mm
Mounting Depth: 135mm
Magnet Weight: 1800g (63.4 oz)
Peak Input Power
800W
Max Input Power
400W
Rated Input Power
200W
Woofer Features
Dual Magnet Drive
High Roll Surround
Extended Pole Piece
Easy Screw Bind Terminal
What sort of amp should i buy to pump these subs really well!
i dun think that would be enough...
i currently have about the same power going into my subs...
2 12" pioneer subs....800w max also...
and i am going to change soon to a bigger amp...
i personally would recommend going a bit bigger amp...
something that would give at least 250w rms to each sub,
gives it more thump...
but also, would the box make much difference?
i have a concealed box atm, should i make a hole in it and port it?
what difference does it make and anyone done it who can verify it's changes?
thanks....tommy
im regards to porting a box, i think it depends on the displacement of the sub when in use (specs should be on the box or manual), some are designed for free air use, other arnt so porting can allow for a slight difference.
As far as i know, the weaker and smaller subs such as the 250Watt Kicker ive seen at Repco comes with a box which isnt ported (at least the one i saw) and i checked the specs of it and its displacement was quite small when compared to more upmarket subs like JL's which have much bigger displacement in comparison and come with ported boxes.
My 12" Pioneer isnt ported, it came with a professionally specified box for it and i guess a port wasnt needed. Im also wondering if porting it would have a noticible difference in SQ.
thats my understanding at least
Take you sub out of the box all together and play it and you will find it makes no noise.
Put it in a poorly made or incorrectly sized box and it will make some noise.
Put it in a well made box of correct size to suit the speaker specs and it will make the best sounding and most noise.
i.e. make sure your install and box are up to scratch before throwing more money on more parts. The volume required for a ported box will be different from the volume of a sealed box for the same speaker. There is also more to it then drilling a hole, you have port size and length to contend with. Speaker specs are there for a reason and your box should be built with them in mind otherwise you are just wasting your time and money, there is no one size fits all.
