Sounds like a fancy heading but not really :D
I just bought myself some DBA 4000 Slotted rotors and am trying to work out what brake pad will best suit the rotor
Driving style is generally pretty laid back eg cruising not much heavy braking but on the same token the reason why i got these is to obviously help pull me up them few meters that might save a few hundred $$$.
Does it actually matter what brake pad i get for them or are they all fairly unversal eg doesnt matter if its for slotted or standard...
options so far (without looking into it to much)
Bendix Ultimates (have heard they are dusty but most are)
race brakes now not sure exactly what sort but yea any particular recommendations.
Any advise would be appreciated
I think most people here run rb74 or something.
I've got some gtst m type brakes in my car and I just put in some project m d1 spec on the rear and ns (street type) on the front. They pull up ok but we'll see on the track. I think I should have got the nr or hc but they seem to be ok at the moment.
I don't think getting performance rotors/pads will help pull you up better all that much over stock items in good condition - they'll just mean the 40th time you go round the corner from 200kmh to 120kmh they won't "fade" and leave you looking at a wall or sand trap.
Either way good luck - if you're interested in the project m call andrew from mu's secret. They're import pads and make some good products and for some reason are still well priced against the aussie stuff.
Good luck with your brakes - I also think if you search out some braking threads they'll be people in the thread who specify that they use the same rotor as yours and what pad they use.
Hi Leigh, I have Bendix Ultimates in the road car with DBA slotted rotors and they are very good. No squeel, little dust, consistent stopping power and reasonable price. The race car uses Hawke Carbotics in the blue compound. They have a much higher coefficient of friction, so if the tyres are up to it, the car does stop in a shorter distance. They don't squeel, need a little heat in them, fair amount of dust, wear pretty quickly and the price makes my nose bleed. But the car stops in much shorter distances, the pedal is much easier to modulate, the tyres are up to it and it stops better for a whole 20 minute race.
Even in brake pads, you get nothing for nothing:cheers:
to true :D
i did a bith of a search and ultimates seem reasonable popular. i think the i might give the ultimates a go and see how they fair up :D
thanks for the feedback guys
Running RB74s in the GTR, still managed to give them a fair rodgering at Sandown. Glazed them I think...
Have previously run Endless NA-Ys in the GTSt at Sandown, pedal was still ok at the end.
Now have a set of Endless CC-Rs 'carbon ceramic metals' to go in... probably be noisy as hell... will report back
You might like to try Lucas pads from Gavsport in Sydney. Alternatively Ferodo 2500 is a good compromise. If you are a pretty laid back driver don't go for performance pads whatever you do, they just won't bite as much as organic hipo street ones will.
Has any body heard about "Green Stuff" Brake pads?? i heard that they are really good they retail for around for about $160 an end.
just heard of them and wanted to know if any one had any pro or cons about the "Green Stuff" product range
cheers..
Im using the RB74s, dont really have any probs with them.  Just sit on the brakes going down my street get a little heat in them, after that no worrys.  When they warm up however :)
Quoting my self is bad...
But anyway I thought I should just add, they are REALLLLLY dusty, just my wheels are brake dust colour to start with, so I dont notice it at all.
I have rb74's on the front with standard rotors and i have white wheels.
Well i used to have white wheels:
Apparently EBC as done a major reformulation on their Greenstuffs (now in version 4) to address issues such as rotor warping/scoring and glazing. Also all over the net, scooby guys are raving about their new pad, the Red Stuff Ceramics. (One rally guy said it was better than the DS2500s!) Might be worth looking into...
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
