1. Get him extremely drunk
2. Steal a sign of a town/suburb from a bout 50 - 100km NORTH of you
3. Place sign 50 - 100km SOUTH with groom chained/tied naked (or with some covering, whatever) to this sign. Works best on a Main road, highway.
4. if all goes to plan, said groom will hitchhike in the wrong direction
5. laugh your arse off
https://www.sau.com.au/forums/topic/55544-bux-parties/#findComment-1082924
Guest two.06l
im looking for silly sugestions on what can and does happen at bux parties
now i have some of my own ideas but i really want to hear some stupid crazy stuff
anyone
im thinking Kagg peircing!!!
The lads took me up to Mt Panorama for 5 days and nights of mayhem. Still getting over it.Paul...DIRTgarage.
https://www.sau.com.au/forums/topic/55544-bux-parties/#findComment-1082929
seen the pics of me at my bucks?
haha.. you show them so proudly prank :)
Last year a guy at my old work god tied up by his friends at his buck party, they stripped him down, got a goat.. and let the goat go to work on him..
*shudder*
glad I wasnt there to have to see that one
https://www.sau.com.au/forums/topic/55544-bux-parties/#findComment-1083424
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
