White 96' R33 GTST, great condition in and out!
108,500km's
Manual
Had full 100,000km service and all belts replaced
Turbosmart dual stage boost controller (hi-lo)
Twin 12" Temperature set Thermo Fans with controller
APEXi S-AFC II air fuel controller
Full HKS Superdragger exhaust, 3.5" mandrel bent with high flow cat
Blitz BOV
NGK Iridium Spark Plugs (brand new)
Heavy Duty Brass Button Clutch
Hicas 4WS
HKS Type 0 turbo timer, displays volts etc.
Autometer Boost guage mounted on A pillar
Dual Stage shift light
Nismo Gear Knob
HKS Pod Filter
Short Shift Kit
Strut brace front and rear
Racing Pedals
Polished Rocker Covers
Red VHT sprayed Calipers
Series II Bodykit
N1 GTR Front Bar
Koni adjustable suspension (freshly reconditioned)
King Spring low springs
Full central locking and 3 point imobiliser alarm
Dual airbags
Hicas 4 wheel steer and ABS brakes
Receipts for many of the above mod's, Lots of money spent!
***INCLUDED IN PRICE***
18" Gold Ozzy Racing Rims 235/45's Brand new
As well as: 17" BSA Racing rims 235/45's all round
Serviced every 5000km's
Can be included (at extra expense), competition stereo. Pioneer double facing head unit ($1400), 220W Pionner front splits with tweeters and 300W 6X9's in Rear. Speakers powered by a 480w pioneer amp. Two 12" SPL Competition square kicker subs in box in boot powered by a 1000W Crossfire amp and crossfire sub control switch mounted under stearing column. setup worth $5000 legitimately can provide model numbers of every component if you would like to check.
Extras: Tommy Kaira Wing sprayed same colour as car, White faced colour changing EL dials and blue axs seat covers.
$22,900 contact via email [email protected] or pm me.
https://www.sau.com.au/forums/topic/55736-r33-series-2-clean-and-modified/
  • 1 month later...
Thanks for previous interest to everyone who emailed, the car is now up for sale again as I have finally moved to the gold coast and its time to get something cheaper. All interest should be directed to email or pm, alternatively my mobile is: 0419778085, msg or call me. The car is in good condition and the km's are genuine. Plz no timewasters. Cheers Matt
this may seem expensive, but if you see the car you will realise the price is reasonable. Car yards are still asking rediculous prices for series 1's. This is a series 2, with enough basic mods for a nice clean and fast skyline. Reasonable offers will be considered, but im not desperate, so no stupid offers either.
33niz : where are u now ? gold coast ? ...
Im lookin for someting in syd :)
i bought the car from sydney origionally....if you want a good car sometimes you need to look interstate...pm me or email me ([email protected]) and we can discuss it if your seriously interested.
23k as is...including competition stereo, extra rims, body parts (wing), dials etc....clean car that attracts attention...can organise interstate transfer at buyers expense...its minimal to most places anyway, not to mention plane flights are very cheap at the moment so to fly up wouldnt be expensive either.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
