Originally posted by PSIKO
bwwwwaaaaaaaap bwaaaaaap
http://www.azale.net/cruise/22.html
yes it was me...
so you were in the black/blue pulsar wa it? I dunno
all I know is car behind me on that corner swung out heaps :(
sorry about the accident I hope nobody got hurt...:)
so do we see pic of this some itme soon or maybe video?
ohh shit I just saw the pic! dang OUCH!
I did not go all the way cuz I knew there would be accident on RB cruise!:uh-huh:
cheers
Joe
https://www.sau.com.au/forums/topic/5588-rollaboyz-crash/#findComment-84713
Originally posted by Pva_Glue
yes it was me...
sorry about the accident I hope nobody got hurt...:(
cheers
Joe
nah mate, I was out in my own car that day, saw a heap of imported cars drive by me and one of them stopped and let me in, so I thought this seems fun
drove up west coast and got to cities car park and saw dan rucci
therefore rb
only stayed at car park, then I left
stayed long enough to see an s13 pulling off a major burnout (details got sent to cops :))
as I left, I was asked if I was gonna do a burnout as well, by Dan Rucci - haha, not likely at an rb cruise buddy!! :)
visit from cops the next day, no thanks
https://www.sau.com.au/forums/topic/5588-rollaboyz-crash/#findComment-84758
Yeh doesnt take much to call an import a write off especially with panel damage.
Who was at fault in this little incident? or was it a group effort. In other words would the guy at the back please forward his insurance details.
https://www.sau.com.au/forums/topic/5588-rollaboyz-crash/#findComment-84864
yer - condolences to Ross and all involved.
BTW - I'm now officially "uninsurable" according to RAC. Can go with others but have to declare that I have had "Insurance Declined" under the Duty of Disclosure Act.
Friggin Insurance Underwriters wield too much bloody power.
https://www.sau.com.au/forums/topic/5588-rollaboyz-crash/#findComment-84874
Yer Mark - my only saving grace is that there was apparently an "independent" witness at the scene confirming that it was just plain "bad luck" caused by other idiots on the road. I think they really got sh1tty, tho, when I sent them a large bill for the lamp pole that Western Power only forwarded to me last month.
RAC are now re-considering - fingers crossed! Won't/can't use RAC for the GTR anyway as all here well know.
Hopefully the new R32 gets loaded onto the ship any day now!
https://www.sau.com.au/forums/topic/5588-rollaboyz-crash/#findComment-84928
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
