anyone from the forums go cruising to the gong on sundays, i saw many skylines down there, also there are a lot of people recording cars on their camcorders, anyone have any footage or pics from down there. Also wanna know whats the whole laps thing all about, i havnt been for so long( getting old) and all i saw was cars going round in circles doing laps of the lighthouse track.
https://www.sau.com.au/forums/topic/55914-wollongong-sundays/
oh brother, the lighthouse happy laps. I dont think ive been out on a sunday this year to the lighthouse. Ive never seen people with camcorders there filming though except on australia day last year. Do many people still go there? Living in wollongong i guess i could just check for myself next sunday, but im too LAZY
one thing i rememer the last time i was there was a r32 gtr killing it around the s bends coming up to the lighthouse. I couldnt believe how fast the fool was going. i remember thinking it would serve this guy right to either:
(i) lose it and miss everyone and fly into the ocean, but then i came to my senses and thought what a waste of a r32 gtr, so thought
(ii) c'mon cops where are you
and(iii) i couldnt help but admire the handling of the gtr whilst thinking u fool
i dont know seriously, if i didnt buy a house i would love to be there soon, but unfortunatly everytime i go to the track it cost me a couple of grand( thats if nothing goes wrong) so itll be a couple of months but when i go down it should be a good run hopefully
After last Wednesday at WSID I think you'd have to work pretty hard to escape the gaze of the Skyline fraternity. There were nearly as many 'lines running as every other car combined.
The last 15 runs of the night were basically R33's !!!
Adrian
My dad lives in Wollongong and so I regularly venture down there. Funnily enough, I hardly see any Skylines but, then again, I don't usually spend time down near the lighthouse or North beach.
My car is currently in my father's keep so keep an eye out for an old man behind the wheel of a gunmental grey R32 GT-R :P
LW.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
