slackers all of you, Jayce and E stuck around just to keep the team a float, they left after the first half, and myself and 2 lovelyy ladies stayed to bring some pride back into the team but with no luck.  5 place guys out of 7 or 8 teams.
sif not mention me i was their for like 45 minutes or so :thumbsup:
  • Replies 1.2k
oh for god's sake gus get over it, stop harrassing us to give you a lift, Sean is over the other side of town for god's sake.....your turning into such a Beau! haha sorry Beau, your a lot better lately.
Im sorry to sound like a cu*t but if one of us can take you then we will, we've seen your previous posts and someone would have offered if they could have taken you.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
