I'm trying to get my grubby l'il mitts onto a SAU sticker or two... I've sent PM's to Prank and Shell:"nothing was the silent reply".I believe there's been a few variants over the day/months/years.Anyone have either one unused that I can buy from them or a CLEAR photo they could email me?Required as soon as poss',but definately before the first weekend of December.With other things I've tried to hunt down,SAU'ers have always helped out;I hope it's the same this time!Thanks in advance!
https://www.sau.com.au/forums/topic/56307-sau-stickersanyone-got-one/
How many you need Jayce? Shell's been super busy, see what i can get my hands on.
EDIT: Guess i should also ask what style, the side quarter window ones with the red hot plates? or the website ones for front/rear windows?
aaah crap Jayce I'M SO SORRY!!...i kept meaning to reply to your PM but kept thinking 'I'll do it later' and have somehow never got around to it... you owe me a slap :(
anyways...the ones i have are the same as the choice you got when you joined the 'official' club.
Just got more made up so just let me know which one and how many! If you can't remember what they looked like just download the membership form in my sig ;)
aaah crap Jayce I'M SO SORRY!!...i kept meaning to reply to your PM but kept thinking 'I'll do it later' and have somehow never got around to it... you owe me a slap :)
Just got more made up so just let me know which one and how many! If you can't remember what they looked like just download the membership form in my sig :)
Hi Shell.Yeah,figured you'd forgotten little old me...(sniffle,sob).Would you have one of each handy?Normally I'd say that I'd swing by your work to pick 'em up and cash you up,but I seem to recall you working WEIRD hours?Either way:have you got one of each,and how can I get 'em off you pronto?
Righto.Given up on most normal sources of stickerage.Now having some made up.All things going to plan,I should have some to show those of you that are doing the trivia night at Jerra pub tomorrow eve'... Has anyone noticed tha SAU decals that have the stove tailights are R34 lights?Bigger outers,smaller inner lights?The ones I've got coming I've had "modified" to be more applicable to 32 and 33 owners.Whilst they're "just for me",have a look and tell me what you think.Maybe if we can nail a reliable source for all SAU'ers,we could have some more made up?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
