Personally, it would be a better thing to get aftermarket adjustable swaybars so you can modify the feel and affect that the sway bars do...
no guarantee that when you get em fitted that it will hadle like you want it to!
my 2 cents is all
well if the gtr's are substancially thicker than stock gts and its dirt cheap then go for it. id just pay that little xtra for whitelines cause simply theyre new and adjustable. they dont cost that much either, i picked mine up for $160 each. i remember something like the part numbers were identical to the s14's or something quirky like that.
As far as I know the Whiteline adjustable bars are replacements for the original, so you need to use the standard brackets and links on the front. On the rear you only need use the standard brackets as the bar comes with its own links.
Be careful with GTR stabiliser bar sizes as they are hollow and therefore may not be as much of an upgrade as you expect.
Hope that helps:cheers:
Yeah the original links for the front are used, however i am running mine at full hard on the front, to try and reduce oversteer and i had to swap the links across... left to right and vice versa..
SK, I fitted the Whiteline GT-R HD rear bar to my GTS4, and it's actually a bee's-dick smaller than the standard bar. Also, it's heavier (weight-wise), because the GTS4's bar is hollow.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
