It's a 1990 model CA31. I had it complied no problems. I've seen a few Earlier cars coming up at auctions, not sure what's happening on that 15 year rule but I may look at bringing one in for parts when they come up.
From what I've learnt there wasn't a standard manual turbo. I could be wrong though. My car was originally an NA manual that was converted to turbo in Japan.
I just found out my fuel tank is very rusty and a massive layer of silt (fine rust) has built up inside the tank and that's what ruined the fuel tank. Was going to be expensive but I managed to source a tank cheap. Hence the reason I'm thinking of bringing one in for spares... *chuckle*
Free plug for Croydon Racing developments (formally Croydon Auto Sports) I have found them very easy to deal with and knowledgable. Highly recommended. :)
https://www.sau.com.au/forums/topic/5676-who-owns-a31_cefiro/#findComment-86425
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
