Hey guys,
Well, we dynoed my RB26DETT 240SX today...
The first time we dynoed at factory boost settings, which on my boost guage was 9 PSI...
We made 320 rwhp or 239 kw, I believe this is about average for stock ecu, stock motor, etc...
Our importer thinks the motor had cams, but we aren't sure... It does have a lope to it, and if I was a betting man, I would think there is...
Maybe you guys can took a look at my dyno chart and give me an idea of what you think...
On the second pull, we upped the boost to 15 PSI, or 1 bar...The car pulled timing and started knocking...
I'm not sure if it was the fact we only had 93 octane gas in the tank, or whether the timing might be advanced too much...
The first graph is of the stock pull at 9 PSI... The second graph shoes all three pulls, with the last two being at 15 PSI...
Thanks!
Chris
Do you guys think the car has cams based on this dyno?
I was really impressed for having a totally stock motor, stock ecu, etc...
The only mods were downpipe and exhaust...
Boost controller turned to 15 PSI for the last two runs...major knocking...and not sure why...
I think you will find that the US rate their fuels differently to us in OZ, so 93 isnt equiv to OZ 93RON, actually i cant recall the unit they use but its not RON.
I take it when you say stock motor, you arent including exhaust, filter, intercooler etc With exhaust, good IC and filters and 1 bar of boost id say that would be pretty typical rwkws for an RB26.
Yeah, for 9 PSI, it's very impressive.. The sound is so loud of those turbos...
The guys that were there were commenting on how nice it sounded..
You would have really thought it was two HKS turbos with all the noise...Very loud for stock...
But, what do you guys think about the whole cam situation? Do you think it has them?
Also, why do you think we were getting knocking on the 15 PSI run?
We think that the timing may have been advanced by whatever Japanese person last had the motor... We assumed it was stock and never messed with it...
But after the knocking tonight, and the the fact that it looks advanced, we are going to check it...
Tomorrow we will be adding 118 octane race fuel and giving a 15 PSI pull...
Just from the graph she looks pretty much stock, there are other stock rb26 pulling higher figures in oz.
Also i believe and knows dynojet dyno give a higher reading than our dyno dynamic ones.
Don't let the low number dicourage u, there are ppls on here with huge hp from a stock motor with some bolt on stuff,
A cam motor has a sharper rise ihp section dependant where it comes on and alot of time when u get a motor, you usually get the aftermaket turbo free before the cams.
Aftermarket cam gear is another giveaway.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
