OK, I'm beginning to think this must be impossible, and I'm gonna feel like an idiot when someone explains it, but I still have the 3 and a half full 2ltr milk bottle with my old engine oil in em, sitting in the garage.
I unscrewed the sump plug on my R32 RB20 (its in an Aus R31 if that matters), drained the oil into a bucket, then poured it into 2ltr milk bottles, filling 3 of them and half filling one. As I've been doing some searching, it seems like 4-4.5 ltrs is the maximum amount you would put into a RB20, but this equates to 7 ltrs.
I'm thinking aftermarket sump maybe? Doesn't look anything special, just black, but I simply can't think of what else is could be. Could the RB20 be overfilled by such a large amount and not crap itself?
Any help would be great as I'm going to be replacing the oil tomorrow and need to know if I need to get another 5ltr bottle...
https://www.sau.com.au/forums/topic/57421-changing-oil-lots-came-out-7ltrs/
could be one of three things
1, aftermarket large sump
2, the last time it was serviced it was over filled
3, you have leaking injector and its filling your sump with fuel
I would suggest you change the oil, keep an eye on it and after 5000kms drain it and take a sample, sample kits are available from most oil companys or oil analyisis companys. The test will tell you alot about what is happening in your engine, they cost around $30
ASHLY
if it was overful it would blow the seals on the engine n prob lots of other things
do u have an oil cooler? that will usually add a few litres of oil to the system
otherwise just put in how much u think it needs, turn it over, check the level and add the amount required as shown on the dipstick
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
