Hey guys,
I recently purchased this turbo and was planning to use it on my ca18 silvia. I now have to sell my car so this turbo is up for sale. Its a rb25 turbo from a R33 which has been hiflowed and rebuilt by Precision Turbochargers in Port Macquarie. Its also been machined and now uses a larger sierra wheel. This turbo has been barely used and is like new. Would be a great upgrade for rb20 or even rb25
I can do $850 posted for quick sale, as funds are low atm :P
I am on the Sunshine Coast if you can pickup
https://www.sau.com.au/forums/topic/57441-rebuilthiflowed-r33-rb25-turbo/
I belive only the series 2 R33 turbo's are BB.......Going by the information i was able to obtain in regards to markings on the housings.......yours appears to be series 1.
I could be wrong of course (been known to happen :rofl: )
sorry to possibly hinder your sale......just feel it is better to be sure before sale rather than have the buyer come back after purchase upset. Good luck.......hope it is BB (that means mine is too then :rofl: )
I could be wrong of course (been known to happen :rolleyes: )
sorry to possibly hinder your sale......just feel it is better to be sure before sale rather than have the buyer come back after purchase upset.  Good luck.......hope it is BB (that means mine is too then :D )
Thanks RiverSide I was under the impression r33 turbos were BB. With the number on the cover can any one clear this up for me? if its either BB or not the rebuild/hiflow cost $1300 so this is a still a good price. Priced for a quick sale.
actually fane, I know for a fact that my R33 Series II turbo has 45v3 on it, not 45v2. If I were to hazard a guess, I would say it would be a rebuilt s1 turbo, which is still ball bearing anyway.
Good luck with sale!
Just throw a spanner in the works again.........what series would it be if it has V4 written on it?
Would that be off a very late model R33?
ps. I am being serious, I am looking at one for the wifes car it is stamped V4. With all those numbers flying around in this thread i thought you guys might have thought i was taking the piss.
stop dribbling shit
i had a vg30et turbo
which had 45v4
seen ones with 45v2
i dunno whats up with it but there all the same in some way
but yeah
series 2 rb20 and onwards turbos were ballbearing i heard
some vg30et turbos were aswell
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
