Hey was Wondering if anyone had aftermarket tie rod ends on there R33 to get more lock out of your steering. There advertised for s13/ s14/ r32 heaps of places do you know if the r32 ones would suit the same size thread as the the r33, bot the steering racks look fairly similar in appearance?? Thanks guys
https://www.sau.com.au/forums/topic/57695-tie-rod-ends/
Thanks Adzmax i think i might just have to go ahead with a choice if i cant end up finding the info, prob R32. Like i said above both the r32 an r33 steering racks appear fairly similar, im guessing the thread sizes for the ends is the same and with that thought cant see how they would differ. However i hope someone has put these goodies on there car an see this thread, an post up what they know.
Just out of interest what s15 bits work on r34?
https://www.sau.com.au/forums/topic/57695-tie-rod-ends/#findComment-1112647
treo, where have you seen aftermarket R32 tie rod ends. I've just started looking into this myself as i've been told i need new front inner tie rod ends and new rear inner and outer tie rod ends. The place that was looking at the car for me said they couldn't find any aftermarket parts and Nissan wanted to charge them a fortune to have some imported from Japan.
I've been looking for other cars that would use the same ends as the R32 but haven't got far yet. I think R32s might be the same as S13s and possibly Z32s. From what i've read R33s are similar to S14s and R34s are similar to S15s.
Sorry i cant give you a more definite answer but if i find anything while looking into the R32 stuff i'll let you know. If anyone knows about what will work in an R32 please let me know.
Also, would this thread be better suited to the suspension or general maintenance section.
cheers,
Tom
https://www.sau.com.au/forums/topic/57695-tie-rod-ends/#findComment-1115185
cheers tom_g
yeah posted something in steering suspension no one was responded very well. You could try this guy bit cheaper than performance shops ive delt with him a few times an its been good just drop him an email www.Slidewizeimports.com/ or try this guy never delt with him but some people i know who have said his good www.garage-13.com.
cheers tim
https://www.sau.com.au/forums/topic/57695-tie-rod-ends/#findComment-1116321
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
