I'm looking at improving the cornering of my series 2 R33 by upgrading the sway bars while leaving the springs and shocks standard. As the car is a daily driver (and I'd like to keep my kidneys where they are) is this a sensible option? Will this modification provide better handling on the track?
Where is the best place to source good swaybars for skylines? I know of Whiteline, but who else supplies good suspension components?
What else can be done to improve the handling of my car without dropping the ride height or having too firm suspension for every day use?
Send some info my way so I can work on dropping those lap times.
Z.
https://www.sau.com.au/forums/topic/5782-swaybar-upgrade-on-r33-gts25t/
Is money an issue? Maybe you can find second hand coil overs that are fully adjustable for height and softness/hardness?
So you can have daily driver setup and race track setup in a few minutes?
But as George and Nikil said. Whiteline is probably your best bet.
Thanks for the info guys.
Well it looks like I'll be giving Whiteline a call.
Can anyone think of any negatives to only changing the swaybars? I'd rather not spend extra money on a full suspension package if swaybars can give me the desired effect. I'll leave the coilovers until I move to a place where I can get out of the driveway without scraping.
Z.
Hi Zane,
make sure u get a decent wheel alignment to compliment your sway bar!!!! else it is a waste!
mmm, ride may be slightly harsher, but you may not notice it,
positives are improved handling
negatives will be, that as your car handles better and you start pushing corners harder, the increased stresses will wear out some components quicker, ie. wheel bearings, tyre wear may change, depending on the size of sway bar you get you may need to get beefier sway bar bushes...check with whiteline about this
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
