I got these dates out of the latest Auto Action. Looks like some of us are in for a busy year.
Wakefield Park February 27th
Bathurst (Mountain Straight) March 19th
Bathurst (Esses) March 20th
Fairbain Park April 10th
Huntly Hill Dapto May 15th
Mountainview June 12th
Ringwood July 30-31st
Bulahdelah September 17th
King Edward Park October 22nd
Chuck in the motorkanas,,,supersprints,,,some serious racing,,,shit a brick i gotta do some calandar work.
Neil.
So can someone please confirm the requirements for these things?
Secondary bonnet restraint?
Fire extinguisher?
Helmet? I presume yes.
CAMS licence? What level?
Anything else?
I think I might have to try one or two of these.
How many runs at the hill do you get in a day?
What general cost is involved?
No, but keep something just in case the scrutineers at a particular event decide you need it. The CAMS Manual actually has a clear exemption for our cars in the regs
Fire extinguisher?
Yes
Helmet?
Yes
Yes, Level 2S
Anything else?
Regulation stickers to indicate tow point and battery location. Sticker kits available from Revolution Racegear.
Club Membership card
I got 4 before it started raining @ Bathurst. could have got 5 if I went out in the rain. Depends on how many competitors turn up on the day and how long the course is.
apart from your own maintenance costs for the car the Licence is $91, and entry fees vary. The Bathurst fee was $110. Accomodation if it's out of town
hope that helps
w00t should be fun.
Copies of the forms to me too :)
For those interested, the registration form is to register you in the State hillclimb series.
You pay $50 and get:
* Mail out of Supp Regs before each round
* Preference for entries at full events
* Points recorded for the championship
You can still go along to all of the events, even if you are not registered! I'm sure each of the events will be posted on SAU so you won't miss out.
4 runs are the minimum for the state series, generally it is more like 6 or 7 :)
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
