  • Replies 62
Posted Images
Panikin, those kits are both great! I like the white one with the big grill at the front. And I've got to get that rear wing, I've been looking for a decent one for mine!
Do you know if it's easy to import here or should I look for a dealer to get them through?
Hi,
Have any of you tried to get out of a 2-door in the shopping centre car parks? It's near impossible not to hit your door on the next car. Why? The seating position in the coupe is forward, close to the door hinges and the door is long so the back seat passengers can get out, thus you have to have the door fully open just to clear your feet when you try to get out as driver.
I plan to buy a 91 gt4 next year as I love the 4-door R32's, just hope I can get out more easily with the shorter doors.
I love driving my sons R33 GTSt coupe on the road, but hate taking it shopping.
Pulp, Powerplay Imports Syd. are one of the stockist for east bear (blue 4dr), sure they willbe happy to take a wad of your hard earned cash..
Steve at STZ auto Bris. will do his best to chase up the impul stuff, Nengun would probably get it all for you no worries either. :rofl:
4dr rules man...yes i too agree, less stress in car parks as u dont need to worry about opening the door and hitting the car beside you.
heres my 4dr, no kit but i love the look
cant really see yhe extra 2 drs, but its there... its the second car from the right
ive been thinking about buying a 4dr and this looks like the right thread to put my question in (bit off topic soz)
i have been searching for an r33 2 dr to buy soonish and after looking at this thread, and seeing ]http://www.prestigemotorsport.com.au/?/au/...ckID=2817
http://www.prestigemotorsport.com.au/?/au/...sp?StockID=2819
these two cars my mind is made up, gonna get a 34 sedan cos they look absolutely awesome and cost the same as a worked 33 thats seen it all.
im not sure about why a 34 sedan costs around 5-6k less than a 2dr 34??
doesnt look like theres any difference besides an extra 2 doors, but 5k difference in price?
always wanted a 34 and this looks like the most comfortable way of getting my 6ft 4' lanky a$$ into a skyline
Good choice TMPTED!! I saw that link the other day, made me want to sell mine and get that one!! I like the R34 shape too, but I'm real happy with my R33. Think they look kinda mean!! ya know what I mean?? Once you've done minor changes like Wheels etc.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
