im not aiming at any great figures, instead a great road car with plenty of response.
Any details about the turbo / setup you are running?
And i hear what you are saying about a responsive street car, but dont be too afraid to throw a mid sized turbo on the RB20. :O
LOL, And again, here come all the disclaimers...i hear what you are saying about no major mods, and it is great power for so little work done, but i think a general trend is starting to emerge in this thread.
And this point isnt shot at anyones results, its just having a think about how/why we keep seeing similar numbers despite the vastly different dollars spent.
My turbo is what most ppl would expect to be laggy, it aint a ball bearing Garret / IHI etc either. Im kinda keen to see someone put a manifold, gate and 2835 on an RB20 :)
I am only using my setup as a comparison as its the only 350-420hp turbo setup on a std RB20 that i have a dyno plot for in 4th gear.
Comparing dyno results (not the most accurate approach i know, but its a start) In 4th gear at :
- 80km/h i have 5psi and 54rwkws vs your 45rwkws @ 6psi
- 95km/h i have 8.5psi and 78rwkws vs your 87rwkws @ 12psi
- 110km/h i have 17psi and 150rwkws vs your 125rwkws @15psi
- 125km/h i have 18psi and 204rwkws vs your 150rwkws @15psi
- 140km/h i have 18psi and 225rwkws vs your 180rwkws @14psi
- 155km/h i have 18psi and 234rwkws vs your 190rwkws @14psi
No doubt with a touch more boost, and the other mods you are considering, you will make more power...
But i plot in spreadhseets most RB20 dyno plots i see and i am starting to form the opinion that the RB20 it is never going to be a power house down low. Put a little 320hp turbo (2510-2530, GT-SS etc)on it and it will make a few more rwkws before 4,000rpm, but after 4,00rpm it will be comfortably overtaken by a slightly larger turbo.
And with too big a turbo, say 600ho GT30 it is never going to flow the numbers it should. So has that lack of low end mid-range, only never to deliver above 5,000rpm to make up for the deficit.
But if you size a turbo around the 350-420hp turbo it seems smack bang what i would consider a good compromise for response, mid range and a top end that gives the little RB20 that real turbo feel / flavour.
There are no doubts exceptions to the rule, and this is only an opinion i have formed based on results seen in this thread, but at the minute i think its a pretty sound theory. ;)
So what was i saying, :D lol, yeh dont be afraid of turbos liek 2535s on Rb20s, who is going to be the first to try the GT-RS :)
throw some cash this way, ill try it!
lol
wat im proud of roy is making that power on basically nothing but r33 turbo, exhaust, fmic, boost....
with minimal cost
turbo 350
exhaust 700
fmic 500
boost 50
everything has been installed by myself
so ill be proud to hit 200+ at a total cost to me of $2500ish
post-7066-1123497253.jpgpost-7066-1123497319.jpgHi Roy
I agree with your statement that the rb20 will never have heaps of power down low and differing turbos will make different power though i do beleive that turbo positioning may also play a part in this though not to sure as there are the high mounts like yours the standard mid mount type and then there's the low mount type like mine with my to4e which even after the last turbo rebuild they still recon isnt flowing enough for the engine don't know how though its big enough anyway getting back onto subject yours is producing unreal hp with the mods you have i would have like to see what it would produce on and engine with cams and ported head adjustable cam gears 55occ injectors it could be a big hp producer as my last dyno graph no longer appears in this thread i'll repost it as you will see i think the hp with standard boost is really good so id have to say it has a lot to do with cams etc and still returning excellant fuel econamy just my thoughts anyway
Cheers Peter
He's a member of this board. I forget his name.
He bought a Blitz SBC-iD off me and I installed it for him some time ago.
He's running a stock ecu that has been remapped.
i havnt done my ecu yet. soon....
any recommedations?
It does depend on who tunes the stock ecu, generally with the pfc you will pick up mid and possibly a little top end with say a pfc as the tuner is able to push it closer to the edge with the use of the pfc's knock feedback.
I.e Chris32.
post-7066-1123497253.jpgpost-7066-1123497319.jpg...though i do beleive that turbo positioning may  also play a part in this though not to sure as there are the high mounts like yours the standard mid mount type and then there's the low mount type like mine with my to4e
Yeh , thats my thinking as well, that the RB20 really benefits from a nice manifold. Also on paper i think the low mount would work a bit better as the exhaust flow out of the turbo would have less bends and be a straighter path...though who can really say for sure the performance difference between the two.
No headwork for me, but i am going to be trialling some locally reground cams in the near future...if they work well im sure to be posting up the results. If they dont work as well as i hope then ill suck it in and get the Poncams/HKS...its just that im kinda curious how these other sticks will go as others have now trialled HKS/Poncams with good results, so will see if the cat still gets skinned when trying something a little different
As for 190rwkws from an R33 turbo, and chipped ECU, thats good bang for dollar, its kinda depressing actually. Be good to see ppl making the same power as RB25s with 500cc less, half a point less compression but the same turbo.
Actually this is going to be way interesting...come on get those cam gears and tunes going, will be very interesting to see the difference in power curve between a std turb R33 making 200rwkws and an RB20 with R33 turb making 200rwkws :P
It may help put into perspective all the claims that the RB20 is gutless, lacks torque etc, as i dont think they are near as bad as ppl make out
lol
with minimal cost
turbo 350
exhaust 700
fmic 500
boost 50
Yeh but what about that bloody front bar you have that should have been mine...thats good for a few kws....i dont think i will ever swallow that deal you got with that bar...im still looking :P
legend01.....
What are the specs of your to4E and is it internal or external gated?
Your graphs look virtually identical to mine except my high boost setting is a little lower.
Mine is internal gated T3/T04E. T04 compressor housing and wheels and a T3 exhaust housing.
I agree about it being depressing roy, spent about 6k with all mods and tuning for the car and making [email protected] what fun those 207kw are!! :P
if anyone can get your hands on a HKS cast manifold.......i'll try it. And i'm hunting around for some 256 or 260 cams for mine to see if it make any difference to the 2530.
FATGTS-R
the turbo started out as a hks t4 had it rebuilt and hiflowed but that proved not to flow enough so it went back in and had a .63 exhaust housing fitted but had to be machined to take the exhaust impeller wheel as the hks item was to big and was kept on there advice the compressor side of things have been hi-flowed it a 50ar housing been machined for a 59 inducer wheel all bolted up on a hks cast low mount manifold with a 35mm hks external waste gate
Cheers Peter
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
