are u still using the td06 20g 8cm turbo roy? has anything else changed between me readin pages 1 thru 60 lol? do u use adjustable cam gears?
Nothing has really changed with my engine. Just running more boost then i use to. I have cam gears though i dont recall the settings. I think the best bet is to have your tuner play with them to find the happy mediul you are after
Its not really on song until 4,500rpm. With bad tyres thats when traction becomes a bit wigidy wigidy :D With semis thats where it just grips and pulls.
And in the true terms of lag, say i shift back to 3rd at 100km/h which equates to say 5,000rpm...if i floor it it shoudl boost quikcly as its in the rpm it makes full boost. If you look at this delay as lag then it does take about 1 second to clear its lungs and pull. Thats where i have been ina few other cars and when up int he rev range they do punch quicker with a little less lag. But we are talking fractions of a second. The only place to use the power is the track anyway and when you know about it you just drive around it.
I made the decision recently no more money is beign spent on the car after my Jan pay, so since i wont have enough cash to finish the new motor odds are the old RB20 will get the new water pump, idler/tensioner, timing belt and 260/8.8 cams i have laying around.
You watch, now that i need the current motor to last unitl Oct 07 so will pull boost back to 18psi, the thng will go bang. Its always the way, when you care it all goes to shit. When you couldnt care less they just keep on truck'n
ain't that the truth :)
can't wait to see how it goes with cams! :laugh:
  • 1 month later...
Thread revival time :D
I just read the entire thread back to front so I may be a little incoherent :D
Roy's TD06 gave me a little inspiration to do some research into Mitsu turbo's and I'm very impressed. Found this page for specs - http://www.zerotohundred.com/newforums/sho...ead.php?t=26477
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
I'm leaning towards the TD05H-16G at the moment for a goal of 300rwhp (~225kw). Is this being realistic?
There seem to be alot of slightly different turbo variations ranging from 340 - 400hp. The main goal is just to have a streetable car thats a bit faster than your average RB20. Anything over 300rwhp would be a bonus, a very very nice bonus :)
A few questions for the wise... since the turbo is only oil cooled, will I have to get an oil cooler to keeps temperatures down?
Is a high or low mount setup recommended?
My plan is to get a china manifold and chop the T3 flange off an weld on a new one to suit, likewise the dump pipe (though slightly more work...)
Lastly, will the internal gate be alright or should I be looking at an external gate and weld the internal up?
Thanks in advance
-Matt
i would fit an oil cooler anyways since the std rb20 doesnt have one unlike the 25 and 26...
besides coolers are cheap, source a volvo 760 turbo in the yard and grab the cooler from it they are setrab units and are farking huge!
the cooler i have is from an 89ish turbo and measures 100mm tall x 285mm long x 50mm thick, rather beastly indeed.
pick up a mocal adaptor plate and some hose and you will be mint.
  • 4 weeks later...
Dont let a good thing die!
Gave it another good workout on the weekend at a skidpan day. Because its 2007 and i need the engine to hold together until after my OS trip i wound the boost back to 1 bar and the rev limit back to 7,400rpm. Still drove the wheels off the thing and again the engine has come through with flying colours.
Gearbox will rack up 190,000kms in the next fortnight and even its still holding up after 40,000kms of TD06.
April could be where it all goes pear shaped. After the weekend on street tyres i dont think i like how the car drives on road rubber, so doubt i will do a track day on street tyrs. This means the expense of yet another set of expensive semi slicks. So next Sandown if all is going well with the new diff, cams and rubber...the old girl will get a last ditch run at 1.5bar in an attempt to get a time out of the little RB20 :P
What happens in april ???
Sandown...its a bit of a running joke with the Vic track guys. 2 years ago 1:25 was considered pretty fast for a modded GTR. They are now going a lot quicker so i need to get all i can out of the RB20. So that means installing my cams and asking the tuner to fix up the air:fuels at way too much boost. I need 270rwkws and a bit more meat at 4,500rpm if im going to do the time i want.
can't wait to see results Troy :laugh:
Valve float could be a problem. But its not the sort of thing that I noticed when I last ran that boost. When its getting the tune checked for that boost if its not making the power it should then safe to say it could be a problem and we may need to wind boost back to a point where its making expected power for boost
are you going to get new valve springs when you get the cams installed? That should fix any valve float probs..?
I would go the performance springs ,I had a set of the gtr springs to go in this build but standard specs said they were only 24kg spring pressure which by many was considered not enough for my application at 22.5 boost . I got the performance springs for the gtr and tested them and they were double that
cheers Peter
P.s roy are u running adjustable cam gears ??? if so can you record what they set them at just wanna compare to my old set up
Forget valve springs. The RB20 is only getting the cams because the tune is a little light up top when i ran 20-22psi. It was only ever meant to run 15-18spi. So if the tune is going to get touched up may as well throw the timing belt, water pump and idler/tensioner that are laying around at it.
But no valve springs. Its a wrecker motor, and based on the fact it doesnt breath a single drop of oil i think its in pretty good health, I have only done 15,000kms on the engine.
So yeh, in my books the only good RB20 is an unopened RB20 :happy:
...i will note the cam gear settings pre cams and post cams. The tuner doesnt want me to try the cams...but fark it. If it loses a bit under 4,000rpm i wont be happy but hoefully it will help the top a little. The engine has a finite life anyway , so... Shits and giggles...how much can a std bottom end take :)
hahahahah yeah damn chasis just wasn't strong enough to fend of that pole engine was fine keeping it as a spare well my second spare never hurts to have to many spares .The engine in the new 32 I bought was a built engine but when I pulled it down for inspection it had major detanition in 1 and 6 rest of the engine was perfict.Mains and big ends looked new still but since it was down that far decided to rebuild it with 40thou oversized pistons (79mm) and put the rb25 crank in it pic's of the where im upto now are in my "again"
thread
Cheers Peter
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
