Had an opportunity to try out the aircon in the GTR for the first time yesterday and guess what, no cold air :)
I have been told that they let the gas out before they ship them? But anyway you look at it it dont blow cold air. It heats fine though.
Has anyone had a similar prob? or needed to have their 'line regassed?
I am also wondering wether the seals are going to be crapped out because of ~6 months without using the aircon. Has anyone had this situation arise?
Cheers,
Ryan.
https://www.sau.com.au/forums/topic/5824-aircon/
just take it to an aircon joint and get it regassed, the only problems you'll have is that perhaps you may have the old gas (r12?) and need to change the fittings to take the new gas (r145A?) AND/OR the valves inside may have become brittle from not having gas in them and died or the mechanical seal on the compressor may need replacing. as for the jap air cons not being able to handle the heat here and dying, i find that hard to believe cus i think it can get pretty warm over there (like upto 35?). what they might have meant was the compressors arent as big in japanese cars as it doesnt get as hot over there as it does here, therefore the aircon doesnt work quite as well as say an australian delivered car.
https://www.sau.com.au/forums/topic/5824-aircon/#findComment-88348
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
