Well I just installed a Boost gauge and a 2-Stage Turbo Smart controller.
Stock boost was running 5psi and spiking to 6psi between 6000-7500 rpm's.
Now running 10psi low boost, 12psi hi boost with no spike.
The boost seems to come on lower down in the rpm.
I think I have just become a boost freak........what a rush.
BTW a big thanks to 51Jay and Co. for helping me put it in.
https://www.sau.com.au/forums/topic/5832-oh-the-joy/
So guys, running stock intercooler on the car? Are you getting the big slump in boost around 4-5000RPM like I hear the R33 will do if theres no aftermarket ECU? Or is that only when going over 12PSI?
Hmm... I might go for a quick cheapo boost upgrade while I save up for my FMIC, PFC and AVC-R if the drivability is still good.
Need to get my HiTech exhaust ordered and on there.. stock system is strangling the engine I am sure :)
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88419
I've got a blitz dual sbc type s. It electronically controls the level of boost, I've got 2 settings; 0.6 bar and 0.8 bar. I use 0.6 bar for most of my daily driving and especially in the warmer weather as I'm still running the stock cooler (I've got a Trust front mount on its way). I only run 0.8bar mainly at night when its much colder. I cant stress how important it is to back off the engine if you've got it on a high boost setting and you hear detonation (it sounds like something rattling in the engine, like marbles) cos if you keep your foot buried you'll be rebuilding that engine :)
Rob
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88615
thats what im affraid of and whats keeping me from running more boost on mine as i cant really afford to be rebuilding the engine.
I get my boost guage this week and will also get a bleed valve... i want to run about 9 - 11psi until my GTR FMIC gets here from Japan.
At present the only mods i have are a POD Filter, CAT Back and Re-mapped ECU.
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88619
definately take it easy on a hot day... alternatively you can do other things to reduce intake temps (the main thing causing detonation on your setup) by installing a cold air partition for the pod filter
i cant see how anyone would really want to thrash it on a 30degree day, so nice for cruising!
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88692
Intake air temp on a hot day on the move is usually around 40-43degrees. Sitting in the staging lanes on Wed night it was running 55-63degrees at the end of the 1/4 mile it was back down to 42 degrees. A bit of a burn out brings it down from around 50-55 to 45
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88728
slayer, over 12psi on the stock cooler is bad news. I used to drive around with 10psi without a s-afc, and there was no getting past the slump in power (not boost) at 5000rpm. Some ppl don't have the same problem, though. Seems every R33 ecu reacts differently.
rob77, whats the trust fmic gonna set you back, including fitting and piping?
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88779
Unsure yet cos it hasnt landed and the workshop is unsure what price they paid for it. When I ordered it the exchange rate was 1aud to 64yen, when it shipped (about 1.5-2 months later) it was 1aud to 68-69yen. Plus you got GST and import duty. Plus it was there 2nd dearest kit for a R33 gts25t, the dearest one includes a intake plenum so that the return pipes can come up the right hand side of the engine. Just the intake plenum is about $1500.
Rob
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88834
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
