I just got my SplitFire coil packs for the GTR this morning! :aroused:
If anybody is looking to buy some, I'd definately recommend Nengun Performance.
I ordered mine on 26/11 and the arrived this morning on 15/12 all for $629
Brent was great to deal with and answered all questions very promptly.
Maybe I can finally fix my my high boost/hi revs mis-fire problem..
https://www.sau.com.au/forums/topic/58684-nengun-performance/
Damn LTSJayce,
what are you doing up so early!!!
On a brighter note, my misfire is fixed :D
Looking forward to a good drive this Sunday. :aroused:
Yeah,I know...sad,isn't it?Truth is,for around 15 years,I rose early to go training.Then I got run over,took 2 years off to enjoy life(which is currently at the 3 year mark...)and I still can't get my body clock turned off...damned thing!
A big thankyou to Richard and you as well Jayce for offering to let me borrow your standard coils, thanks guys :P
Seems anything ignition related seems to have packed it in over the past week, first ignitor started screwing up, and now two coils are arcing all over the place.
But... Ed got me a brand spanking new ignitor pack (although you need to re-wire the electrical harness going into it or the car wont start) and when I get some new good coils and cooler (coming very soon), up she gets filled with C16 and were going for the big hitter dyno run (pictures it now... :Bang: )
A big thankyou to Richard and you as well Jayce for offering to let me borrow your standard coils, thanks guys :D
Hi Nik;
Well...you got my attention! Does this mean the misfire is fixed?
Regards
Slowly getting there, just as another wrap, Ed is doing an awesome job with the car. Its been a learning experience for both of us and its coming along quite nicely, dont think I can give him enough praise :D
  • 2 months later...
Do nengun performance have splitfire coil packs for r34 skyline cos i need a set for my car.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
