First off, I've got quotes and stuff just to see the costs involved.
Iceboi your a retard... Seriously I am asking people for rides and where other people can and you start shit.. GTR34 or whatever, your 1 year older and asked the same question in this topic, so how about we all stop this crap and don't post.
And GTR34, PMs about my mother aren't very nice. Also TJ probably doesn't give you "crap" cause he meets you in dark alleyways. Your 1 year older than me, and calling me hardcore, seriously man, get a life.
And everyone that has posted on this page is a keyboard warrior. Laugh at me if you will but I doubt anyone would say that to my face.
  • Replies 147
1- name your time and place - since ur in class 9 - 3, it will have to be after that i spose... lol if you think i wont say it to your face
2 - if gtr34 is 14 and a hot female, ill happily meet her in a dark alley .. erm i mean , erm.....
3- get some personal hygiene.. been told that one of your lift providers said you smelt like a homeless man. think im talking shit? i can provide a name and logs if you like. to quote someone, ive got quotes !
4 - btw, ill say this all to your face, 0403471736, call me if you cant ride your bike to meet me, or no one is willing to give you a lift to meet me.
LOL , keept it clean boys (no Pun intended.)
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
