I went to browse the gallery, and it was mostly errors :)
Warning: main(/home/websites/93/www.skylinesaustralia.com/photopost//cathead.tmpl): failed to open stream: No such file or directory in /home/websites/93/www.skylinesaustralia.com/photopost/templates/showgallery.tmpl on line 3
Warning: main(): Failed opening '/home/websites/93/www.skylinesaustralia.com/photopost//cathead.tmpl' for inclusion (include_path='.:/usr/local/lib/php') in /home/websites/93/www.skylinesaustralia.com/photopost/templates/showgallery.tmpl on line 3
Warning: main(/home/websites/93/www.skylinesaustralia.com/photopost//albums.tmpl): failed to open stream: No such file or directory in /home/websites/93/www.skylinesaustralia.com/photopost/templates/showgallery.tmpl on line 4
Warning: main(): Failed opening '/home/websites/93/www.skylinesaustralia.com/photopost//albums.tmpl' for inclusion (include_path='.:/usr/local/lib/php') in /home/websites/93/www.skylinesaustralia.com/photopost/templates/showgallery.tmpl on line 4
etc etc
https://www.sau.com.au/forums/topic/59261-gallery-errors/
Because the problems we had were due to an intrusion, many files were overwritten by the hacker. These files had to be restored from a 4am backup and I had updated photopost during the day to the latest version, so what has happened is that the photopost files are version 4.8.2 but the database is version 4.8.5 ...
I will upload the files again and she should be right. :)
Christian
https://www.sau.com.au/forums/topic/59261-gallery-errors/#findComment-1131095
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
