we've gotten chromagus to 40% on first try so far. we have a raid scheduled tomorrow so we'll see how we go now.
firemaw is horrible though if you dont get the positioning and tank transitions going.
havent made it to an mc for a few weeks now so im losing out on NS gear badly. still have my gutgore ripper just need a new OH and should be cool :D
  • Replies 416
Posted Images
My guild is in a stage of rebuilding but we managed to get rag down to 40%.
On another note ZG's been nerfed hard! My guild couldn't bring down High Priestess Mar'li before but after the patch it only took 2 shots. And Bloodlord Mandokir use to take atleast 8 goes, but we killed him on the second run. That's with a lot of noobs also.
We've only started MC run but last week the guys got Rag down to about 40% on first run. I'm proud of the guys considering many don't have FR gear. Now if they'd only get off their lazy asses and get some FR gear! lol.
good work :P
we just took down thundarian got our first thunderfury and i must say that is easily a 15man raid instead of what i thought was meant to be 40man. he dropped super quick
since last maint we have taken down up to broodlord (i got the head which is cool :mellow::P bronze flight rep ftw) so now the rest, hopefully we down chromagus tonight
chromaggus down! fkn!
we got our shit together, and seemed to be real simple the time we did it, only 5 deaths as well :rolleyes::) :) !!!
Bloodgfang and mage shoulders dropped, and chromatically tempered sword as well
this is good because earlier in the week we got the untamed blade, and also thunderfury like i said before. :)
we are just going through different strats for nef's room atm, its a bit of a ball breaker, but yeah, chromaggus was pie
chromaggus down again and nef to phase2! so awesome.
i also scored my first bit of bloodfang, being the shoulders, because they dropped again :O need 2 more for the 3piece bonus and only one damn nightslayer for the 5piece bonus.
edit: before i forget, we now have gotten rag down to 19% before sons, no pots etc, just pure smashing, bout 2 deaths because they missed the knockback call and landed in lava. perd blade dropped for the second time and again went for over 100dkp
Well, I'm officially retiring from WOW. RL and WOW clashed and it's time to rebuild my life. I wish I could tell you guys what happened but it wouldn't be fair on the other parties involved.
Overall it's a fun game but it's just so time consuming. I can understand the addiction but now I realised how much I've missed out on back in the real world.
Woooooo Rag 32% before spawns, hope we can do it again this week haha.
It is time consuming, but you can dodge around it to play and do work/rl things to. Best thing if you wanna do that is take a break for a month, get back to WoW and keep certain days for shit you really need/want to do IRL. Good luck
NEF DOWN!!!@@!@!@!@!!@@!!@!@FKN!@!@!1!
if anyone wants to see our guilds site its:
Eternal Requiem
bwl is down to a 2 night clear pretty much, we'll see how we go tonight, we have chromaggus and nef left. chrom is just cake atm no matter what breaths
60 lock on Blackrock with AlterElectus, will be running Blackwing Lair tonight, Guild is up to 2nd boss in there, and can finish MC in 3.5 hours. Now anyone else on blackrock think that the sever should just kick over and die, instead of these queues and lag issues.
the sooner blackrock gets migrated to the new (hopefully faster and more stable hardware the better) only problem is they started with the east coast servers. blackrock is westcoast :P
amazing what happens when we finally get enough ppl online. razor to firemaw done all first attempt. not bad seeing we had 10 ppl with no epics and it was our first shot at firemaw. still we are behind where we should be.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
