Hey guys
I was thinking of selling my gtst and buying a R32 gtr.
How does the gtr compare to gtst in performance, i have 217rwkw and it feels good, how will that compare to a standard gtr? Would handeling and suspension feel betar on the r32 gtr then the gtst?
With the car been so old now would there have to be alot of work done to it like a rebuild or new turbos ect?
How will they both compare all together?
thnx in advance :D
https://www.sau.com.au/forums/topic/59526-r33-gts-t-vs-r32-gtr/
They say the GTR feels more like a race car. Also GTR's are AWD unlike the GTS-T which are obvisously RWD, you can config your GTR to be a RWD too. With a 15 y.o. car you should be changing some parts. Depends on the condition of the car too. I wouldn't be upgrading the turbo first, coz the turbo isn't really important. You can drive without a working turbo but u cant drive with dodge internals which are bound to fail. The GTRs' suspension is much different to a GTS suspension. GTRs' are harder, more for track racing.
yeah awd sure is great, but how would my r33 compare to stock gtr in proformance wise? (i have 217rwkw)
My concern is that the rb25det engnies have a massive drop in the torque strating from 3000rpm to 4500/5000rpm and all the manegments just seem to just move the drop or make it more smoother but never can get rid of it. Does the rb26dett have this drop. i was told that it doesnt?
thnx ;)
:D
I just bought myself a stock R33 GTR, and comparing that to my stock GTS-T, it pulls much much harder :P
It takes a bit longer before it gets up and going, but fark, once it starts, it pulls all the way to 8k. The GTS-T was a nicer drive around the city. With the GT-R, turbo's start spooling at 3, and are fully boosting @ 4.5k revs which is a bit high for my driving style. It is more of a race car than a street car, but I absolutely love it to death.
So to answer your question, there is no drop in torque once the GT-R gets into its powerband. It keeps pulling and all you want to do is keep your foot planted while you change gears. Mind you, the first 3 gears are pretty short (180 clicks) :D
Well a locally delivered WRX is detuned for aussie fuel, only has 195kw as compared to the Jap version that has 206kw. (Same as factory GTR)
So the GTR still has a minor power advantage.
I would say a stock GTR (in good health) would easily give an STI a run for its money.
Bit more boost pressure and an exhuast on the GTR and you should easily leave it behind.
Not being biased at all :P
A few other members here must have run into a few sti's in their time, should be able to tell us some stories :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
