i have been suffered by a stupid engine problem (killing spark plugs) for over a month and have spent around 250 on the plugs as well as some amount of money spent in another workshop (they are good but i guess they are just too busy to look at my car properly)
finally, holidays are all over, so i wake up early today and gave Ben a call see if he is available. Anyway, i was running late and dropped the car in around 3.00pm...i took 1 hour bus trip back to monash uni plus 1 hour walk to McDonald's and back home~~~!!! Guess what~~~!!??? as soon as i got home, i got a phone call from Ben...all fixed...unbelievable right~~~!!!
All i want to say is Ben you are the best in VIC and thank you for your help~~~!!!!
https://www.sau.com.au/forums/topic/59573-racepace/#findComment-1145173
i have been suffered by a stupid engine problem (killing spark plugs) for over a month and have spent around 250 on the plugs as well as 450 to other workshop (they are good but i guess they are just too busy to look at my car properly)
Its not a question of "other" workshops being busy or anything mate.
They just simply dont know what they are looking at.
Ben will work it out, and it wont cost you the earth like other workshops who just p|ss fart around for weeks on end taking pot luck guesses at what the problems are.
There are too many average joe workshops in Vic, especially in the western suburbs. 99% of them have no idea
https://www.sau.com.au/forums/topic/59573-racepace/#findComment-1145212
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
