Not sure if he's touched a RB30, but Martin at Speed Technology tuned my RB25DET + Wolf 3D+. ST are agents for Wolf, so they should know their stuff. And they work closely with AEM on the development of the Wolf.
Trouble is they are probably closed for Xmas / NY. Can't hurt to give them a try on Wednseday - 9873 5400.
Do you have a laptop? Worst case, I could give you my current map, and we could juggle it a bit to suit, at least it would get you running OK (mine punched 180 awkW).
thanx for the offer greg its much appreciated. i actually got my ecu from them and they gave me an rb25 map. my mate who has ef turbo with wolf helped me tweak it abit so im cruising for christmas at least. i will probably get them to get it right when finished running engine in. i thought if i could find someone as helpful as u with a 3.0 i might be able to get a map from them to save a bit of time/money when i take it there as they didnt have a 3.0 map. all the best for christmas buddy. cheers. Dave.
that has absolutely nothing to do with me so shove your :  "i know where your from" up your arse.
have you pmed him with threats to sue yet?
Where in that thread did he say it had anything to do with you?
Take it to PM or i'll give you another 14days. And that goes for a number of other people. Stupid comments might be tolderated in other sections...
But not this one. This is a section to help people. And rubbish posts such as these are far from helping anyone and i will deal with them accodingly
Yep, Martin from Speed Technology does good work.
You should see the absolute variety of cars they get in there.
From a Proton dealer who has one of those littel GTI things making 145kW at the wheels (I've been in that and it's scary)
To a 5xx ci big block in a fully custom thing making 180 kw and 10,000nm of torque at like 2500rpm, before it almost spun the dyno over!!
He's pretty good at what he does.
BASS OUT
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
