Need to sell my car: this car has made 540Hp over 400 KW on 18psi
The car is Black in colour with Red leather interior 2 recaro bucket seats, Sports steering wheels with lap timer, Apexi Rev/speed meter, Sound System with Kenwood 7" DVD player with TV recievers Eboost Gauge and 2 autometer gauges in a dual gauge holder mounted on the pillar.
Performance
RB30 Bottem End, Wiseco forged pistons, Gabbless Rings, steel rods, arp bolts all round, O ringed, and reciever groved ceramic coated chambers and pistons, Nismo Racing Oil pump, Nismo Water pump , Head has been ported with HKS Steel Values and Springs, GTR style head, Copper head gasket, Tomei Stage 2 Cams and gears, This engine was built 1000kms ago with paper work and warranty Built to handle 700Hp + @flywheel
Turbo: T66 Garrett 900HP Turbo dual ball bearing rollers, external Tial wastegate with Stainless steel manifold. Large Front mounted intercooler with Blitz blow of Value. 3inch Stainless Steel exhaust system.
Fuel System : 950cc SARD injectors Malpasi Fuel Reg, Bosch 044 fuel pump with surge tank GTR in tank pump working as Lift pump.
Ignition: M & W ignition pack, external coil pack 10mm custom made Spark plug leads.
ECU : Microtech LTX12 computer requires a 3 bar Map senor to run more than 18psi.
Microtech Dash
Exterior: 400R side skirts and rear bar , Drift wing (flat boot)
Tyres 20” x 8.5 Front 20” x 10.5 rear Kaokic rims
Brakes: Cross Drilled and slotted brakes all round.
Suspension : Tein HA adjustable suspension
$35000
https://www.sau.com.au/forums/topic/59778-r33-s2-1996-400kw-on-18psi/
  • 4 weeks later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
