whats wrong with silver? ive always thought it to be one of the best allround colours for cars. looks sex with white wheels too.
if i ever get a respray i would think long and hard about doing silver with a ice blue pearl, or the yellowey-green colour that alot of car makers are using now. (my mums falcon is this colour).
i agree that its good to be different and not copy, but dont want to be too flashy.
out of the three colours, the gtr purple would look good, but be a bastard to keep clean.
  • Replies 45
My last R32 was silver and I loved it.... However, I would like to move on to a colour that is a little more rare, and will make the car stand out when it comes time to sell..
I really love the puple so I thinki it is what I am going to go for.... Might also look into painting the car black, and putting a purple pearl into the paint...
Yeah i have more pics of that Exact car......
Plus the colour is actually a stock colour, limited BUT stock
Ok... Here is todays challenge!
Find out what colour code that paint is.. Would Nissan be able to tell me?
Can you please email me the pics of that car MADGT4?
[email protected]
From another thread:
The R33 GT-R Midnight Purple has been done quite a few times before, it still looks good, but I suppose something a bit more unique like II or III would be good.
Midnight Purple - #LP2
Midnight Purple II - #LV4
Midnight Purple III - don't know :(
Heres the PDF file: http://dupont.co.jp/dupont-refinish/color/.../nissan/lv4.pdf
I don't really know what I'm translating, but if you know paint code recipies then stuff like "binder", "balancer" and "flop controller" might make sense to you...
1st Part (Colour base):
*from top to bottom on the extreme left*
Skyline
Black H.S.
Binder
2nd Part (Pearl Base):
*top to bottom on the extreme left*
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
3rd Part (Colour Base):
Skyline
Black H.S.
Binder
Balancer
4th Part (Pearl Base):
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
Note: At the top of the 3rd column across from the left on each of the parts it says "1L Combination Amount".
Now if you can make heads or tails of that that'd be great, because I'd hate to think that I've wasted my time.
ive painted my R32 kandy red its very nice but very hard to paint and very expensive compared to the colours you have posted.
midnight purple I, II or III would look nice as well as cherry black and they arent very common.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
