Hi Guys
Strut Braces Group Buy 3
I have a friend who imports strut braces and I can get some good deals from him if I buy in bulk. This is the going rate
buy 1 for $70 - I have 3 x r33 front and 1 x r32 front left over from last group buy.
buy 5 for $65 each
buy 10 for $65 each
buy 15 ir more for $60 each
Postage is $13 for 1 and $20 for 2.
Here is the list of strut braces I can get
skyline
R33 front strut brace
R32 (incl GTR) front and rear strut brace
Silvia
s13 front and rear strut brace
Supra
Fits JZ80 and 70 series front strut brace
Soarar
Fits on soarer twin turbo and non turbo front strut brace
If you guys are interested reply to this thread and tell me exactly what you want. It just makes administration work a little easy when it comes to organising everything. Sorting through PM/EMAILs/thread replies and SMSs is a nightmare
Over the next few days/week I will see how many people are interested and let you all know what the cost will be. If everthing goes good I will then need the money from the buyers and I will get the parts and send them out to you guys. If everyone pays up quickly the buyers should get their strut brace within 7 days.
END DATE: 15/01/05 or earlier depending on the amount of buyers.
https://www.sau.com.au/forums/topic/60146-strut-braces-group-buy/
hey received my bar yesterday put got it installed good quality and great sale would reccomend to anyone considering.
glad to see a happy customer.
still 2 r33 front strut braces left and 1 front r32 for $65 each
can you get a strut brace for the rear of the r33 i cant seem to find any?
My supplier is in the process of making one. Will post up a thread when they are available. Not for the next month atleast.
Sounds good.... ill put ya number in my phone and call ya once i finished playing golf on sunday.... Depends on if i get busted taking beer on the coarse again..... Cause if i suceed ill be too busted to drive sunday night.... LOL
Hey Raf
just as a heads up on the one i bought for 2JZGE soarer - doesnt quite fit as the inlet plenum is just a tad too high
tried using some washers under the bracket but the bolts from the suspension wasnt long enough to accomodate it.
will have to modify the brackets to allow for this :)
cheers
Justin
sorry to hear about that. My supplier told me it will fit fine. It it a stand plenum? But I guess he did not check it close enough I will tell him that. But I might have a solution!!!
With the s13 sr20 strut braces they fit fine with the the sr20 motors but with the ca18 it hits the plenum slighty. So what we do here is the bend the bracket just before the bolt holes slighty. Put the braket in a vice and give it a slight bend so the bar sits a little higher. If this is not clear let me know and I will send you some pictures. Otherwise I hope it works - let me know.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
