My Supplier drop the price because he owns 100% of the factory in China from 2005 so it's a very good time to buy those coolers now
so don't worry guys my supplier got more than 10000 in Stock in Australia.
same factory as Hybird.
Core size: 600x300x76 bar and plate
HP Rating: 500-600hp
Flow Test: 381.3cfu
Fully Polished
3" inlet and outlet
Comes with end tanks, fully welded.
Low Cost, High Efficiency
$300 delivered
Core size: 450x300x76 bar and plate
HP Rating: 400-500hp
Fully Polished
3" inlet and outlet
$295 delivered
Core size: 600x300x105 bar and plate
HP Rating: 500-1600 hp
Fully Polished
3" inlet and outlet
$400 delivered
Time for the Postage
Sydney within : next day or 2 days working days
Mel within: 2 to 4 days
Adl: 2 to 4 days
Perth: 3 to 5 days
we have enough people already. So please contact me if you need any... we can do next day delivery.....
P.S Guys No COD, only accept bank deposit or Money order or Credit Card
I am located in Brisbane so Brisy ppl can pick them up.
https://www.sau.com.au/forums/topic/60263-hybird-intercooler-310-deliveried/
Can i inspect and pay cash.... im in Brissy....
Ill come and look and buy and post quality as a third party member to help others confidence...
Ive got a cooler off this guy. not all that happy about the after payment feedback..etc.
but did recive goods as stated in the title. (altho wasnt next day delivery like stated originaly)
cheers.
So my question is how come your cooler costs $300 or 310 i got confused as u have 2 prices but anyways. How come the piping is so expensive.... Local performance shop wants $700 for a core and $250 for piping and install. That includes polishing core and end tanks???
I assume they just have expensive cores and make their money that way...
I asked if they would plumb one of your cores and they laughed and told me if i wanted to take a chance then go for it, but they will not plumb it, because they dont trust them... Whats the go....
Its called a biased opinion. 'they dont trust them so they wont plumb one'
wtf is that ment to mean? in other words 'no, because we wont make enough money off it'
ask for a reason why they dont trust them and post up, i need a good laugh. theres many of these coolers going around australia at the moment, i have alot of friends using these coolers, (not all from this seller).
coolers are flow and pressure tested. lets here from these workshops why there so shit. :P
sorry about the prices....300 is the special price for the cooler so.....I have my own reason that pipes are charge for that amount of money....but if you can get cheaper pipes then you can just buy it from me and let them to do the pipes, just don't care what they say....just post up what they say i need a good laugh as well....
So who has bought coolers off this guy?
I am interested but he doesnt have a trader rating...
Any1 got 1? oppinions..
I need a cooler about 450x300x76
Cheers.
Greg
So im just looking for the best priced package...
If im gonna spend $1000 with piping and fitting it myself why would i not just get it done at a shop???
If you did cooler piping and all the bits needed to fit for like $700 id be in...
Hey... my mate marty bought one today... he is wrapped with the unit....
Thought i should say "Thumbs up from him"
He just needs piping now.... (trust him to make me find it)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
