I have been reading about people's fuel pumps failing or not being good enough to handle the power of their cars.
For this reason I was thinking of putting in a different fuel pump in my 32 GTST when I get it (it's waiting in Japan for the boat). I figure it's a safe insurance. Same as doing the timing belt.
I don't plan to get above 200rwkw, I don't think I will even get close to that. I don't have a large budget. All I will be doing is FMIC/exhaust/EBC/12-14psi. I may consider more in the future, but I think if I plan to 200RWKW max, I should be happy.
So my questions;
1) Is the standard pump going to handle this? If not, what should I look at? I have read a fair bit in the forums, and searched, but it seems all the people upgrading are aiming at a higher power than myself.
2) Do I need to run a relay and my own power to it? Or is this only for the bigger ones? (People saying they need to with the 044 in other threads)
3)I have read about people having an internal and external, do I need both? Why would you want both?
4) What does a pressure regulator do? Obviously regulates pressure...but at what point do you need one, and why?
I'm sorry if it has all been answered before, but I could not find the threads. I searched for an hour or so.
Cheers
Chris (eXc)
https://www.sau.com.au/forums/topic/60549-which-fuel-pump/
So my questions;
5) I'm sorry if it has all been answered before, but I could not find the threads. I searched for an hour or so.
Cheers
Chris (eXc)
My suggestions follow;
1. With that list of mods you are going to be lucky to get to 170 rwkw, as you have no tuning capability.
2. The standard pump will handle that. The next step up is usually swapping to a standard GTR pump, good for ~265 rwkw, they don't need a relay or wiring changes.
3. There are many ways to plumb up a fuel supply system, at your target power level don't worry about them. Simply take the GTST pump out and stick a GTR pump in.
4. To get a little more out of the injectors you raise the fuel pressure at the rail. OK to do if you only need say 10% more flow, any more than that and it is better to upgradew the injectors.
5. Yes, it has all been covered many times. You just need to learn the correct terminology. Don't forget to search the content of posts, not the title of the thread.
Hope that helps:cheers:
PS; the standard RB20DET turbo is not going to handle 14 psi.
https://www.sau.com.au/forums/topic/60549-which-fuel-pump/#findComment-1148852
5. Yes, it has all been covered many times.  You just need to learn the correct terminology.  Don't forgetto search the content of posts, not the title of the thread.
https://www.sau.com.au/forums/topic/60549-which-fuel-pump/#findComment-1148854
You could possibily look at a Walbro gss 341 that flows 255 LPH. You can currently pick one up on Ebay in Aus for 180 including postage. I have one of these pumps are they are very good. They are a straight swap with the standard unit.
https://www.sau.com.au/forums/topic/60549-which-fuel-pump/#findComment-1149308
You need to be careful when selecting Walbro pumps. As you can see from the attached, the GSS341 is rated at 255 lph, that's at zero boost and at 13.5 volts. If you install one in tank with the standard Skyline wiring it will run at 12 volts, that's 215 lph. Then add some boost, say 20 psi (1.35 bar) and they are down to 180 lph.
Bosh pumps on the other hand are rated at 73.5 psi, that's a rail pressure of say 40 psi plus 33.5 psi (2.3 bar) boost. That is why, generally speaking, Bosch pumps are physically larger, they need to be to provide the pumping torque at their high rated pressures. If you are looking at running high'ish boost or upping the rail pressure, then this feature is more likely to appeal.
The same guys that tested the Walbro pumps also tested a number of Nissan pumps. If you take a look at the following graph you can see that a standard R33 GTR fuel pump out flows the Walbro GSS341 at 13.5 volts and 30 psi by about 10%. The standard Z32 fuel pump is 5% better than the GSS341 (the standard R32 GTR fuel pump is basically the same as the Z32).
Hope that is of some use.:D
https://www.sau.com.au/forums/topic/60549-which-fuel-pump/#findComment-1149336
  • 4 years later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
